Author Topic: Cheap MAFs any issues?  (Read 3000 times)
Re: Cheap MAFs any issues?
« Reply #15 on: 19 March 2010, 22:05:43 »
When was air filter last changed? And pattern or genuine?
Martin_1962
« Reply #16 on: 19 March 2010, 22:05:55 »
Well next dry weekend day I'm going to do the petrol filter just in case.
Then see if anyone local has a good MAF to try.
I know of one member with a 3.2  VXL V6 - I have his DVD to return :-[ :-[ :-[ :-[
Still tempted to change as I cannot afford to change car until my daughter leaves school (5 years to go)
Martin_1962
« Reply #17 on: 19 March 2010, 22:07:03 »
K&N but not heavily oiled - however it has been in for over 4 years and washed regularly. Only had the original fail last year.
Martin_1962
« Reply #18 on: 19 March 2010, 22:12:52 »
Air filter was in 2.0 as well - no MAF issues.
Old 2.6 MAF was not oily either.
Will clean Air Filter this weekend and also the fuel filter after I have done the brakes
« Reply #19 on: 19 March 2010, 22:13:50 »
if you are going to try maf , try air temperature sensor as well imo..
vic
  • Aldershot (Hampshire)
« Reply #20 on: 20 March 2010, 11:37:53 »
Preliminary check for a dodgy MAF would be;
* with ignition off disconnect wiring to MAF. Start engine whilst disconnected and if it idles better than before its more than likely the MAF. However, also,
*Check all air hoses between air fliter and throttle body for splits/tight connections. Unmetered air entring the throttle after the MAF can give the same symptoms as a fubar MAF.
* Check air filer is clean
* Check all vaccuum pipes for leaks.
Symptoms of a fubar MAF include hard starting,stalling, hesitation when accelerating, rough idle,surging, and increased fuel consumption, among others, but they're the ones you'll probably notice first. :y
Varche
  • middle of Andalucia
    • Golf Estate
« Reply #21 on: 20 March 2010, 11:47:08 »
I have had a Ebay airflow meter company one on mine since last summer and it is still working. The car doesn't run well but in my case I think it is some other as yet undiscovered issue.
The new MAF cured instantly the stalling at junctions problem
« Reply #22 on: 20 March 2010, 15:20:14 »
Search Results
Search results 10matches found for Control Valves & Units, Sensors & Flow Meters + Airflow meters
Omega       Part Number       Retail Price       Normal Trade       Trade Club
Airflow meters
2.0 8v                                         90510154       £234.00       £210.60       £182.29
2.0 16v                                         90411957       £142.00       £127.80       £110.29
2.2                                          90530463       £95.50       £85.95       £77.56
2.5/3.0 to ENG 08137540                                      90510156       £244.00       £219.60       £190.35
2.5/3.0 from ENG 08137541                                     90541591       £231.00       £207.90       £179.89
2.6/3.2                                         93171760       £168.00       £151.20       £131.09
2.0DTi                                         93171356       £144.00       £129.71       £112.06
2.2DTi                                         93171355       £116.00       £104.40       £90.10
X25TD                                         90528813       £195.00       £175.50       £151.55
Y25TD                                         93174628       £183.00       £164.70       £142.47
