Author Topic: Reconnecting Heater Hoses  (Read 1239 times)
Radar
  • Berkshire
    • Elite 2.5 Auto
« on: 21 March 2010, 19:34:24 »
After flushing the heater matrix, i wanted to check i refitted the hoses correctly/safely. The link below: http://www.omegaowners.com/forum/YaBB.pl?num=1185891036 shows the hoses but mine had a green semi circle clip on them also which originally sat right at the back of the bulkhead.
Now i have put the hoses back on as far as they go (before the pipe gets bigger) but the green clips do not push back to the ends as before? What i am doing wrong?
I ran the car for 10 minutes with no leaks but am still intrigued.
Any pointers would be welcome. :y
I_want_an_Omega
Re: Reconnecting Heater Hoses
« Reply #1 on: 21 March 2010, 19:40:23 »
Did you get a good positive CLICK when you plugged them in? Ig you then pull the hose it should be solid ,,,,,,,,,
Matchless
  • Nottingham
    • A white van
« Reply #2 on: 21 March 2010, 19:47:43 »
the green clips are fitted to new hoses and come loose the first time the hose is fitted.
To check you have fitted the connectors properly, try pulling on the hose, if the latch is engaged properly the hose will not move, if it comes off, you didnt push it far enough on to the pipes before engaging the lock ring.
« Reply #3 on: 21 March 2010, 19:49:41 »
They are locking clips. You need to fit them in the connector BEFORE attaching the hoses back on the matrix stubs. The connectors are a watertight fit without them, but if you have them then why not refit them IMO?  ;D :y
Radar
  • Berkshire
    • Elite 2.5 Auto
« Reply #4 on: 21 March 2010, 20:04:09 »
Thanks for the replies. I did get a click when i put them back on and they seem securely in place (fingers crossed!)
the green clip was on before i refitted, it just sits flush with the hose now as opposed to being 2 inches infront of the hose prior to starting the job.
« Last Edit: 21 March 2010, 20:06:14 by radar »
Page created in 0.024 seconds with 20 queries.
