Author Topic: mfd message - LOW BEAM FLD/ VISION  (Read 1739 times)
hawksy
  • crewe
« on: 22 March 2010, 17:51:50 »
on my multi function display a warning has come up saying - LOW BEAM FLD / VISION i have checked all lights and everything is working , the car is a 2003 omega elite 2.2 dti with xenon lights , can any help.
                          regards mike
Re: mfd message - LOW BEAM FLD/ VISION
« Reply #1 on: 22 March 2010, 17:54:53 »
Sensor on FRS wishbone or sensor on RNS radius arm or a level motor in either or both headlamps goosed. very well documented  :y
hawksy
  • crewe
« Reply #2 on: 22 March 2010, 18:30:50 »
thanks for your quick reply , can you tell me what frs is please and if it is level motors can they be replaced or is it new lights required , regards mike
« Reply #3 on: 22 March 2010, 18:36:31 »
Have a look at the sensor first to see if the common fault of the arm being disconected has taken place.
This is the new style sensor in question:
hawksy
  • crewe
« Reply #4 on: 22 March 2010, 18:45:52 »
just had a quick look at sensor and arm is very loose / broken ,will look tomorrow in day light , thanks for your help , regards mike
ferrari jason
  • Skelmersdale
« Reply #5 on: 22 March 2010, 18:51:05 »
if its loose its prob popped off the ball joint i had this prob on my old diesel omega that i taxied i found some off that white plumbers ptfe tape worked to tighten it up
megaomega123
« Reply #6 on: 22 March 2010, 18:51:36 »
A cable tie to hold it in it's holder has done the job for me for over a year now  :y
« Reply #7 on: 22 March 2010, 20:09:34 »
Ooops! ::) FNS front near side  :y
hawksy
  • crewe
« Reply #8 on: 23 March 2010, 09:23:23 »
hi , just a quick update checked front n/s wishbone this morning and popped arm back into socket , quite a tight fit so hopefully every will be ok , as warning message has gone off mfd , many thanks again for the info , regards mike  :) :)
Page created in 0.026 seconds with 20 queries.
