Author Topic: Erratic idle at times??  (Read 3156 times)
vbelen4
Re: Erratic idle at times??
« Reply #15 on: 22 March 2010, 21:20:18 »
Time ago I experienced erratic idle. Discarded ICV, etc, finally it was due to a defective ECU temp sensor.
Smooth
  • N.Ireland
« Reply #16 on: 23 March 2010, 20:55:18 »
also tried cleaning the breather pipes and no avail,doing my rather head now,no codes present,have tried a bottle of engine treatment in the tank today,hope this helps,anyone any ideas....cheers
If Jesus had a licence he would drive an MV6
  • Auckland
    • Mazda MPV
« Reply #17 on: 23 March 2010, 21:39:17 »
Has anyone got Tech2 or "My Naff Code Reader" in NI who can look at live data for you?
When SWMBO got a Golf last year it had similar symptoms. I spent ages checking for air leaks before getting a tool to read live data which told me that the throttle wasn't closing when it should.
Turned out that some clown had glued a sliver of wood inside the throttle motor to prevent it closing properly. This had been done to mask a stalling problem caused by a faulty temperature sensor >:(
Removed the wood, replaced the temperature sensor and cleaned out the breathers and order was restored :y
I would start by checking that there isn't a problem with the brake servo or the vacuum pipe. I can think of other things it might be (temperature sensor, throttle motor) but it doesn't make sense to swap things unless they are known to be faulty.
Page created in 0.025 seconds with 16 queries.
