Pages: 1 2 [3]  All   Go Down
Author Topic: cam belt ok but engine just spins over and dosnot  (Read 4960 times)
jordan890
  • manchester
Re: cam belt ok but engine just spins over and dosnot
« Reply #30 on: 25 March 2010, 21:08:41 »
there where no warning lights it just lost power and stopped it was running  :-Xon gas when it happend the car is fitted with duel fuel you press a switch to change between the two petrol/gas
« Reply #31 on: 25 March 2010, 21:10:22 »
im in moston   m/c :-/   but ive left the car at work wich is at newton heath manchester
Thats a shame, if it was this side I could have nipped over and had a quick look but i'm stuck at the moment ripping plaster of the walls and ceilings at home. If you can leave it a week I will be able to get over then.
jordan890
  • manchester
« Reply #32 on: 25 March 2010, 21:11:58 »
hope not left it in works yard i drive an artic for a living so it should be safe in the works yard :P
« Reply #33 on: 25 March 2010, 21:13:31 »
I'm confused ... (not difficult)  you say the engine is "turning over" but with "no compression"  .. what are you basing this on ???
When you get someone turn the starter motor  can you actually SEE the bottom pulley turning ?? This will PROVE the engine is "turning over"
You say the cam belt is OK .. do you mean the belt to the alternator ?? which is the auxiliary belt NOT the cam belt
« Last Edit: 25 March 2010, 21:16:05 by entwood »
« Reply #34 on: 25 March 2010, 21:19:20 »
When you get someone turn the starter motor  can you actually SEE the bottom pulley turning ?? This will PROVE the engine is "turning over" .....
but doesn't show the cam is turning.  ;)
Is it possible to see the cam via the oil filler cap? That would show the cam belt isn't snapped (but not whether it's jumped a tooth or three.  :y
« Reply #35 on: 25 March 2010, 21:19:45 »
I'm only pulling your leg.  ;)  ;)
jordan890
  • manchester
« Reply #36 on: 25 March 2010, 21:19:59 »
where is the cam belt situated as im confused as he might have been looking at the wrong belt he also took the oil filler cap of and he saw the cam shaft rotating     ihope :-/
« Reply #37 on: 25 March 2010, 21:22:05 »
Tha cam belt lives right at the fron of the block under a cover behind the auxillary/fan belt.
« Reply #38 on: 25 March 2010, 21:24:03 »
Agreed .. but I thought a step by step approach might help ... lets just confirm the starter motor is actualy turning SOMETHING ... :)  then we'll work out what !!!
jordan890
  • manchester
« Reply #39 on: 25 March 2010, 21:30:44 »
i will check that in the morning thanks to everyone for the help ;)
jordan890
  • manchester
« Reply #40 on: 27 March 2010, 12:55:49 »
checked car again starter turning faster than engine so there must be no compresion is this the end of the car or will i be able to get it sorted out
jordan890
  • manchester
« Reply #41 on: 27 March 2010, 12:58:05 »
if the cam belt jumps teeth will this damage the valves
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #42 on: 27 March 2010, 15:41:20 »
depends how many teeth :-/
other rides
Pages: 1 2 [3]  All   Go Up
