Author Topic: Don't want to bother Daz on his hols but.......  (Read 2951 times)
Re: Don't want to bother Daz on his hols but.......
« Reply #15 on: 01 April 2010, 17:52:27 »
I remember 'idle' being adjusted on my 2.2 via the EGR  :-/
Nope.
You may have remembered me testing your egr, which would have affected idle, but certainly not an adjustment method...
« Reply #16 on: 01 April 2010, 17:53:14 »
Nope.
Thats what i meant  :)
MutantCav
  • Gainsborough
« Reply #17 on: 01 April 2010, 17:53:37 »
I would clean the AICV and check the MAF with a known good one if you have someone close by...tickover is not normally lumpy unless you have blockage or maybe a slight airleak etc...mines smooth at 500rpm
« Reply #18 on: 01 April 2010, 18:51:09 »
Bionic, if you want a really perfect idle (like I did) prepare to drain the budget.. starting with a new maf,
new icv,new valves, new gaskets under the plenum, new dis and cables, sound injector cleaning and so on..believe me not worth..
even a small hole in the exhaust or any leak from anywhere else will mess up everything ;D so dont bother.. :y
ps: I also find that NGK 4 electrode sparks are better for my cars idle..
« Last Edit: 01 April 2010, 18:53:10 by cem_devecioglu »
« Reply #19 on: 01 April 2010, 19:01:51 »
Air con compressor on Estate bearings seized (to be replaced in warmer weather) so running no aircon and 2 lit aux belt (shorter) - tickover 500 rpm and dead smooth.
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #20 on: 01 April 2010, 19:58:14 »
ticked over nice on Monday. . Wonder if it could be that lead that looked worse for wear?
Welung666
« Reply #21 on: 01 April 2010, 19:59:46 »
Any codes stored? I'm not all that far away from you if you're stuck.
Bionic
  • Leicester
  • Why drive anything else?
    • 1999 F/L 3.0 Elite saloon
« Reply #22 on: 02 April 2010, 09:20:49 »
Hiya wellung666,
sent you a PM but with failing bionic legs like mine I am seriously stuck to a set of wheels. Possibly another transplant using wheels would be better than the metal bits I currently have stuck in me?
I could then excuse my ass as the exhaust...... Hmm, thats worth a thought or two  ;D ;D ;D
