Author Topic: Windscreen washers - poor perfromance  (Read 1662 times)
markfree
« on: 01 April 2010, 19:46:27 »
My windscreen washers are not working properly as the stream only just reaches the windscreen.
Checked for leaks (none that I can see), and cleaned the rubber filter/grommet thingy (was clear anyway) - is it time for a new pump?
Re: Windscreen washers - poor perfromance
« Reply #1 on: 01 April 2010, 19:48:51 »
If you've clean out the filter/grommet, checked each nozzle is clear than maybe it is time for a new pump. Have you checked that the pipe isn't trapped anywhere along its length?  :y
KW
« Reply #2 on: 01 April 2010, 20:43:56 »
If the jet of water is "limp" (ie, it curves on it's way to the screen from the nozzle), then it will be as Andy said (blocked filter/blocked pipes/weak pump).
If the jet is visibly "strong" (ie, nice straight line from nozzle to screen), then use a pin to adjust the aim of the washer nozzles.
I know violence isn't the answer, I got it wrong on purpose.
alank46
  • South Devon
    • 3L Elite Estate 1996
« Reply #3 on: 01 April 2010, 22:42:26 »
Hi
I had this problem, it was a kinked pipe right by the bonnet hinge.
Alan
georgie
  • Buckinghamshire
« Reply #4 on: 02 April 2010, 10:15:56 »
May be the pump, apparently they are a fairly common item to wear out. If you canot hear a lively whirr from behing the front numberplate, when washers are operated, then the pump may be seizing. To change you'll need to take the bumper grill and crossmember off. Its not that difficult. Push the pump away from the resevoir and pull out. Tenner delivered on e*ay
markfree
« Reply #5 on: 02 April 2010, 10:26:24 »
Thanks for all the advice guys - so I'll check for kinks (in the pipe  ;D), adjust the nozzles and if all else fails I'll get a new pump - they're only a fiver off ebay.
And a happy easter to all my readers ;D :y
« Reply #6 on: 02 April 2010, 10:37:29 »
You  definitely don't need to remove the bumper and it's back plate) The only thing you need to remove on a pre-facelift car is the grille, you can then see the pump. As you then say, lever/push away from the bottle (shove a pencil in the hole if you want to keep your screen wash  ;)) and go easy in this cold weather you don't break anything else. A kettle of warm water will help to soften the wash pipes to allow removal from the old pump.
« Reply #7 on: 02 April 2010, 11:15:38 »
Never seen one wear out yet
« Reply #8 on: 02 April 2010, 12:02:23 »
I'd to replace mine last year, the water jet would just about hit the bottom of the screen when I was stopped. No obvious signs of wear inside it, but a new one sorted it. .....
Yes. I'd done all the above checks  :y
dbr
  • north east.
    • 1997. 2.5CD petrol
« Reply #9 on: 02 April 2010, 19:24:38 »
Listen to pump. If sounds to be running 'normally' then pin in jets and look for kinks where the pipe goes into bonnet
« Reply #10 on: 02 April 2010, 19:32:09 »
The alternative to that, is to break into the discharge pipe - passenger side wing - from the pump, run it & see if there's a good flow & pressure of water.   :y
markfree
« Reply #11 on: 02 April 2010, 19:40:59 »
As an update I fixed the problem by adjusting the nozzles - didn't realise they could be adjusted - you live and learn - thanks for all the replies :y
« Reply #12 on: 02 April 2010, 19:44:08 »
