Author Topic: Cam Belt Advice.  (Read 3100 times)
jonny2112
  • Bangor NI
    • 2.6 Elite
Re: Cam Belt Advice.
« Reply #15 on: 04 April 2010, 02:19:59 »
Sounds like an old fashioned 'cambelt party' in the making  :y
I_want_an_Omega
« Reply #16 on: 04 April 2010, 07:45:00 »
You got the 30 mm deep crank ring spanner too?
No, how deep does it have to be?
« Reply #17 on: 04 April 2010, 08:21:22 »
Not particularly, but a 'combination' type spanner isn't ;)
« Reply #18 on: 04 April 2010, 10:07:10 »
Pehaps I should have said .... offset ring spanner  ;)
Mikes1670
  • Hull
« Reply #19 on: 04 April 2010, 11:17:41 »
Would a 30mm deep socket do the job? I think I have a 30mm deep socket kicking about in the garage somewhere (bought to remove the wheel bearing nut in order to remove the front strut of an Astra). Am I right in thinking it would be used to turn the engine over once the belt is fitted?
I will see what I think to the DVD.
« Reply #20 on: 04 April 2010, 11:22:12 »
no
I_want_an_Omega
« Reply #21 on: 04 April 2010, 12:09:08 »
So, its like an ordinary ring spanner but the ring is at an angle from the handle? How much of an angle, 45 degrees?
TIA
« Reply #22 on: 04 April 2010, 13:54:40 »
TIA
One like ....
rather than .....  :y  :y
I_want_an_Omega
« Reply #23 on: 04 April 2010, 17:30:05 »
A picture is worth 1000000 words - thanks
