Author Topic: You know when you start one job....  (Read 3805 times)
MickAP
  • South Derbyshire
« on: 04 April 2010, 18:51:17 »
You come across something that possibly needs doing.
Finished the rear brakes, the handbrake needed adjusting so it held equally on both sides, and replaced the anti-rattle springs for new ones, on the pads.
Also greased up the rear brake lines, I reckon they should pass the MOT ok next month.
Anyway on to the oil/filter change, done that and sorted the iffy drain plug, nice and tight now.
When I removed the cover plate (on the under tray) for the oil change I found a nut in there. I wondered where it has come from. I removed under tray partially but couldn't see where it may have dropped  from.
Stuck it all back together and everythings fine.
Worried about this nut though, on closer examination it is the same as my exhaust manifold fixing nuts on the 2.2.
Question is would they be the same on the TD exhaust manifold as on the 2.2 petrol engine. I haven't looked there yet.
Mick
« Last Edit: 04 April 2010, 18:51:56 by MickAP »
Beard
  • West Midlands
    • Vauxhall Omega
Re: You know when you start one job....
« Reply #1 on: 28 May 2013, 22:16:29 »
Hi, Does anybody know how to change the springs on the rear suspension? as the spring has broke and is in need of urgent fixing.
need to know as quick as possible; thank you  :o  ::) :y
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #2 on: 28 May 2013, 22:19:57 »
Look in the maintenance guides,
You'll get more help if you start your own thread :y
other rides
noel
  • frome somerset
  • i feel the need for speed
    • 02 omega 2.6 v6 cdx auto
« Reply #3 on: 28 May 2013, 22:25:28 »
as already stated you need to start your own thread :y
but please click on link for guide to replace rear springs (need to change a s a pair) :y
http://www.omegaowners.com/forum/index.php?topic=90537.0
noel
  • frome somerset
« Reply #4 on: 28 May 2013, 22:32:17 »
Mick
i suspect they are the same,but im sure someone will be along shortly to confirm ;)
Broomies Mate
  • Bristol, UK
    • Stuff!
« Reply #5 on: 28 May 2013, 22:36:12 »
Mick
This question was asked in 2010 - I'm sure they appreciate the response though.  ;D ;D ;D
« Reply #6 on: 28 May 2013, 23:06:24 »
 ;D
« Reply #7 on: 28 May 2013, 23:13:49 »
I changed mine yesterday using the following method.
Chock front wheels very safely.
Handbrake off.
Jack rear off car up as high as you can and then support it with axle stands and also place wheels under the car.
Undo lower shock mount.
undo 13mm nut/bolt on droplink.
Using a long lever of some description (a scaffold bar about a metre long is perfect) lever the suspension arm down from the chassis to allow the spring to be taken out.
Lever the arm down again to fit he new spring,then reassemble in reverse order.
Removing and refitting the springs is easier if you have a second pair of hands to either operate the lever or remove/replace spring.
I didn't,but it would have been easier if I had.
I jacked up,and changed spring one side at a time.      Hope that helps.
amba
  • Medway towns
    • German V6
« Reply #8 on: 29 May 2013, 11:43:52 »
Much easier if you drop the rear diff on a trolley jack and also undo the rear exhaust rubber hangers.Makes the spring almost fall out and replacing is as easy.
Only a few mnore bolts to undo and do up but much less grief than wedging bars etc in ...imho
« Reply #9 on: 29 May 2013, 11:57:52 »
And dont forget it needs to be in neutral with the handbrake OFF.
« Reply #10 on: 29 May 2013, 12:25:10 »
I found it much quicker without bothering to drop the diff tbh,even working by myself.It took less than an hour and a half to change both. Each to their own though. :y
noel
  • frome somerset
« Reply #11 on: 30 May 2013, 22:16:32 »
Mick
chuff me so it was :P
