Author Topic: Aargh crap....  (Read 4791 times)
Re: Aargh crap....
« Reply #15 on: 04 April 2010, 16:57:30 »
:-[ Its that bit which gets me really, i am confident enough to strip everything else down. When mine goes will have a bash myself  :)
Do it that way, nought to go wrong ;)
Re: Aargh crap....
« Reply #16 on: 04 April 2010, 17:42:12 »
Email sent...
As per email - what rotton luck!
If when you turned it over, water was coming out of no4 cylinder, it points  to a rather  spectacular head gasket failure!
Not uncommon on 2.2...
And yes, I am happy to assist  :y
Kiksomass
  • Northampton
  • Its all about the bass!
Re: Aargh crap....
« Reply #17 on: 04 April 2010, 18:41:21 »
Email sent...
James you're a star!Anyway,started to strip down and found a little mayo in breathers but no where near what I thought I'd find.I'm guessing more water to cylinder than water to oil where the break in the gasket has occured. I'm out of my depth a bit now though. Cambelt still on,exhaust manifold still on and throttle area still on. Camshafts exposed and lots of fresh oil sitting there. Dunno where TDC is,but I've got all the cam lobes as horizontal as poss and while manually cranking it feels more free.Without a Haynes manual I'm not going much further. Chicken!! :-[ ::) :D
Growing old is inevitable....growing up is OPTIONAL!
Re: Aargh crap....
« Reply #18 on: 04 April 2010, 19:11:11 »
I've replied to your email mate :)
I have no doubt we can sort it. Was there any white smoke? Or smell of fuel, in the expansion tank?
I am off out with the dogs for a bit, but should be able to check messages again by 10pm  :y
charlie
  • sunderland
Re: Aargh crap....
« Reply #19 on: 04 April 2010, 19:23:48 »
pm on route
Re: Aargh crap....
« Reply #20 on: 04 April 2010, 20:40:29 »
Back - a bit early.
Was too dark for long walkies!
Email sent G.
Clouseau
  • Telford
  • Keeping the dream alive...
Re: Aargh crap....
« Reply #21 on: 05 April 2010, 09:40:02 »
You wil need a decent torque wrench, that will accurately give you an 8NM torque (although as I recall the lowest torque quoted is a 6NM).  I already had a half inch drive T/Wrench but it wouldn't go anywhere near that low. Ended up buying a £50 3/4 drive from halfords which I have to say is an excellent tool.  You can't mess about with aluminium heads!
Be prepared for a looooong job!  That's why the dealership prices are prohibitive.  Aim for a day to strip down and a day to put back together and as already stated the key to success is to be methodical. Take lots of photos, list what you are doing. Don't forget to add antifreeze, oil and filter to the HG gasket kit on your shopping list. Good luck; it isn't too difficult but hugely satisfying when it's all back together again and fires up on the first turn of the key :y
« Last Edit: 05 April 2010, 10:31:32 by rjlangton »
Re: Aargh crap....
« Reply #22 on: 05 April 2010, 10:34:30 »
I have that very same torque wrench myself, and would recommend it.  Its £40 to those who have access to Halfords trade.  Much better than the Seeley one I used to use.
Re: Aargh crap....
« Reply #23 on: 05 April 2010, 10:35:54 »
i have both 8-60Nm & 60-300Nm Halfords ones, got them on Trade, found them excellent  :y
Re: Aargh crap....
« Reply #24 on: 05 April 2010, 10:38:11 »
THats the big bertha (£50 trade) isn't it?  Are you strong enough to use it :o
Re: Aargh crap....
« Reply #25 on: 05 April 2010, 10:42:28 »
Only ever gone up to 110Nm for wheel nuts, thats a bit of a struggle  ;D
Re: Aargh crap....
« Reply #26 on: 05 April 2010, 12:35:13 »
Likewise,  I have that torquewrench  too
Having done lots before, I reckon I can do this job in a (long) day
The only obsticle would be if the head was found to be warped - as the job would then be held up while it goes off for machining..
Re: Aargh crap....
« Reply #27 on: 05 April 2010, 12:42:28 »
Doable if no snags I reckon :y
Reminds me, I really must do the HG on the Rover again ;D.  Ever changed an oil rail on one before?
Re: Aargh crap....
« Reply #28 on: 05 April 2010, 12:49:54 »
My thinking too. Hopefully I can get the old girl sorted this coming weekend..
I'll give you a hand with that - it was a laugh last time :y
Looks quite accessible with sump off?
Re: Aargh crap....
« Reply #29 on: 05 April 2010, 13:01:08 »
IIRC the oil rail has the main bearing caps built into it on the k series? Might be wrong. :-/
