Author Topic: 1612 fault code  (Read 1341 times)
griffin
  • West, Wiltshire
  • a
    • 2.6 CD
1612 fault code
« on: 04 April 2010, 09:50:07 »
Hi All
Can anyone help/advise. Not used the car since last weekend but when I statreted it this morning it was very hesitant and started roughly. Once started seemed to drive ok thought I'd do a peddle check and came up with the following 1612 code.
problem/solution
TIA
Welung666
Re: 1612 fault code
« Reply #1 on: 04 April 2010, 09:58:24 »
1612 is immobiliser, no or wrong signal.
griffin
  • West, Wiltshire
  • a
    • 2.6 CD
Re: 1612 fault code
« Reply #2 on: 04 April 2010, 10:15:00 »
Thanks for the info. Is there anything I can do to rectify?
« Last Edit: 04 April 2010, 10:22:22 by cdgriffin »
Re: 1612 fault code
« Reply #3 on: 04 April 2010, 10:42:59 »
would this be a case of a loose transponder in the key? never had this fault so see what others say.
Welung666
Re: 1612 fault code
« Reply #4 on: 04 April 2010, 11:02:15 »
That would be my first check, followed by popping the steering cowelling off the check the receiver ring is still in situ and fully plugged in.
Re: 1612 fault code
« Reply #5 on: 04 April 2010, 11:07:11 »
think code unrelated to symptom
griffin
  • West, Wiltshire
  • a
    • 2.6 CD
Re: 1612 fault code
« Reply #6 on: 04 April 2010, 12:39:20 »
Thanks guys, just coinsidence about poor starting. The speedo, rev and mig panel were removed beging of last week so that may be the cause possibly.
griffin
  • West, Wiltshire
  • a
    • 2.6 CD
Re: 1612 fault code
« Reply #7 on: 04 April 2010, 16:43:50 »
May be a stupid question but I've taken the steering cowelling off (top section) but not sure what I'm looking for.
Sorry!!
griffin
  • West, Wiltshire
  • a
    • 2.6 CD
Re: 1612 fault code
« Reply #8 on: 06 April 2010, 11:17:24 »
Morning!
Checked everything and all seems to be intact, do I need a tech2 to reset the codes etc?
Thanks for any advice.
