Author Topic: ABS ECU  (Read 1540 times)
Road Hog Mad
  • Cheshire
ABS ECU
« on: 07 April 2010, 17:02:10 »
Just checking before I replace it... (friends car)
ABS & TC light on permanently (use to be intermittent)
Speedo inoperative (use to work intermittently)
Steering goes heavy intermittently, (some what weighted but not too hard to turn)
I have got my self the odd screws to remove the ABS ECU and have sourced a second hand ABS ECU from one of the same model (3.0 AUTO ELITE - S Reg).
Looking at it and to make more room for me to do the job I would remove the battery and a water hose. Any tips for this and am I right in assuming it is the ABS ECU.
« Last Edit: 07 April 2010, 17:03:28 by pjwright »
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
Re: ABS ECU
« Reply #1 on: 07 April 2010, 17:04:40 »
it may not be the ecu,it could just be a wheel speed sensor fault.you need to have it code read
other rides
Road Hog Mad
  • Cheshire
Re: ABS ECU
« Reply #2 on: 07 April 2010, 17:05:43 »
The engine management light is not on, who would come and read it for me?
« Last Edit: 07 April 2010, 17:06:19 by pjwright »
henryd
  • west cornwall
Re: ABS ECU
« Reply #3 on: 07 April 2010, 17:07:02 »
the abs ecu is seperate and is code read seperately
other rides
Road Hog Mad
  • Cheshire
Re: ABS ECU
« Reply #4 on: 07 April 2010, 17:10:12 »
so how do you read the code to see if it is the speed sensor? and would this cause the abs and tc lights to come on etc.
Re: ABS ECU
« Reply #5 on: 07 April 2010, 17:13:18 »
NOT the speed sensor ... classic ABS ECU symptoms IMHO ... had exactly that on the old 2.5 ... refurbed ABS ECU (£130:00   :(  ) fixed it  :y :y :y
henryd
  • west cornwall
Re: ABS ECU
« Reply #6 on: 07 April 2010, 17:14:23 »
you will need a suitable code reader and yes any fault with the abs will light tc and abs lights as the traction control uses the abs to brake the spinning wheel
« Last Edit: 07 April 2010, 17:15:06 by henryd123 »
other rides
Re: ABS ECU
« Reply #7 on: 07 April 2010, 17:16:28 »
I would say it sounds like the ABS ECU as well.
Road Hog Mad
  • Cheshire
Re: ABS ECU
« Reply #8 on: 07 April 2010, 17:48:16 »
on your sig I notice cam belts done for £200, mine will be due in around 15,000 miles so if you're local I may contact you, i have done the tensioner and aux belt.
Re: ABS ECU
« Reply #9 on: 07 April 2010, 18:59:22 »
Abs ecu breaked mate - classic symptoms, especially a 1998.
Did the Estate by just removing top hose - a bit tight though.
Road Hog Mad
  • Cheshire
Re: ABS ECU
« Reply #10 on: 09 April 2010, 14:44:24 »
Tried to get this off today, 3 hours later and only 3 out of the 6 screws removed I gave up, told my mate to take it to a garage :@
Road Hog Mad
  • Cheshire
Re: ABS ECU
« Reply #11 on: 09 April 2010, 14:56:59 »
So... anyone in Manchester area who would do this please PM me with a price..
Page created in 0.026 seconds with 20 queries.
