Author Topic: 2.5td fuel economy  (Read 3960 times)
PC Techy
  • Bath
Re: 2.5td fuel economy
« Reply #15 on: 13 April 2010, 13:03:51 »
Box came from a company in germany MAL electonics, Just connects to 4 cables in the main ecu plug. Fully adjustable from normal power to 30% power increase.
http://www.mal-electronics.com/html/englisch.html
It's listed as td powerbox, only took 2 days to arrive from germany aswell.
DUE TO CUT BACKS, THE LIGHT AT THE END OF THE TUNNEL HAS BEEN SWITCHED OFF
hoofing it
« Reply #16 on: 13 April 2010, 13:15:54 »
The only accurate method of calculating fuel consumption is to brim the tank, use it, then re-brim.
My previous chipped manual-boxed TD returned 33mpg running locally around here - proven!
If you want to chip an auto, you'll need to exchange your 'box for an AR35 version.
When chipped, the 'standard-fit' AR25 will quickly go into meltdown.
Increased torque and all that!
How difficult is the Ar 35 swap? I presume that they are different in size and length, that would mean mountings propshaft swap etc. As much detail as you can manage would be great.
straight swap mind to use the ar35 tc
hoofing it
« Reply #17 on: 13 April 2010, 13:23:09 »
is your car a auto or manual. if auto make sure its got a AR35 fitted going by the nm the Ar25 will destroy itself.
PC Techy
  • Bath
« Reply #18 on: 13 April 2010, 14:04:14 »
its manual, so no worries
georgie
  • Buckinghamshire
« Reply #19 on: 13 April 2010, 16:18:57 »
So the AR25 and AR35 are identical appart from their innards??
If I buy one I just want to make make sure that I rip out all the extra bits(if any that are needed) from the scrapper
Also what mileage is too high for an AR 35. I know it depends on usage and misusage but any opinions would help.
hoofing it
« Reply #20 on: 13 April 2010, 16:27:38 »
mainly the torque convertor :y
Omegatoy
  • UK
« Reply #21 on: 13 April 2010, 19:41:21 »
you need to use the td bellhousing and the torque converter!!
