Author Topic: Exhaust Manifold Heatsheilds  (Read 1081 times)
amba
  • Medway towns
    • German V6
« on: 15 April 2010, 11:27:22 »
I am almost convinced that my passenger side exhaust manifold or gasket ?? is causing a leak as every time car is started from cold seem to get a ticking noise until engine warms up.
On closer inspection this morning it seems that 1 of the heat sheild bolts is missing and am wondering if this would cause a "blow" if the threaded hole in the manifold was tapped down into the flow of the exhaust.
Does this seem logical or is the missing bolt just  nothing to do with it ?
pembsomega
  • pembrokeshire, wales
Re: Exhaust Manifold Heatsheilds
« Reply #1 on: 15 April 2010, 11:31:39 »
i doubt it would blow? my first omega didnt have any heatsheilds left. , is it loose if a bolt is missing? perhaps the shield itself it rattling until it expands under heat and stops itself??
« Last Edit: 15 April 2010, 11:31:57 by pembsomega »
amba
  • Medway towns
    • German V6
« Reply #2 on: 15 April 2010, 11:37:24 »
Good thought,I must admit I could see why it would blow if a bolt was missing,but unsure if threaded hole went right through.
Will get a few spare bolts and see if it improves if it is secured better...but didn,t seem to have any movement so might be thermal expansion and all that .
« Reply #3 on: 15 April 2010, 11:56:41 »
They are blind holes so would not cuase a blow if bolts are missing
Page created in 0.039 seconds with 20 queries.
