Author Topic: Lack of throttle response on DBW  (Read 3767 times)
Re: Lack of throttle response on DBW
« Reply #15 on: 18 April 2010, 13:33:05 »
Was it the same/similar symptons Tunnie, no revs then a quick release and press and all OK :question
No, i had zero throttle response until i restarted. When it was unresponsive i just had an unusually high idle of 1.2k rpm.
Sensor on pedal seems OK. Just had this happen, no throttle until switched off then on. Tunnie, did you get the 0340 cam sensor code at all. :question Put the reader on it and no stored or pending codes :-/ Is it possible to have an intermittent fault with the cam sensor and not to throw an 0340 :question
Having trouble remembering now, was about 4 years ago. Think i had it tech2'd and it was showing cam sensor error
« Reply #16 on: 18 April 2010, 14:08:12 »
Think I`ll bite the bullet and replace the cam sensor. IIRC it`s been known to throw spurious codes and unexplained malfunctions without revealing the 0340
« Reply #17 on: 21 April 2010, 10:08:58 »
Update.
Changed the cam sensor yesterday (genuine) now I`m getting this quite often. Any more ideas please :-/
« Reply #18 on: 21 April 2010, 12:13:06 »
try throttle position sensor imo..
« Reply #19 on: 21 April 2010, 12:30:50 »
Update.
More often!? thats odd... agree with Cem throttle sensor itself now
« Reply #20 on: 21 April 2010, 12:42:19 »
Update.
On the throttle body or pedal :question
« Reply #21 on: 21 April 2010, 12:48:21 »
Update.
I'd say throttle body, not really seen pedal sensor fail  :-/
« Reply #22 on: 21 April 2010, 12:52:57 »
New body then I suppose. TPS is sealed unit I presume :'(
« Reply #23 on: 21 April 2010, 12:56:16 »
I bought tps seperately.. :-/
« Reply #24 on: 21 April 2010, 12:59:56 »
Can be purchased on it`s own for cable operated throttle but on the DBW it appears to be part & parcel of the throttle body.
« Reply #25 on: 21 April 2010, 13:02:47 »
ok then.. imo, before shopping test with some members tps close to you..
