Author Topic: Checking Proceedures for P0500  (Read 1222 times)
Zhing1
  • Manila, Philippines
« on: 23 April 2010, 02:27:04 »
Hi. Does anyone have the checking procedures for Fault Code P0500 "no vehicle speed signal". Much appreciate your feedback.
Welung666
Re: Checking Proceedures for P0500
« Reply #1 on: 23 April 2010, 06:07:21 »
Does your speedo work?
The speed sensor is on the rear left wheel, check the wiring and that it is secure as a start :y
« Reply #2 on: 23 April 2010, 10:13:15 »
In which ECU is that code stored?
Zhing1
« Reply #3 on: 23 April 2010, 11:51:55 »
Hi, Probably the main ECU.
« Reply #4 on: 23 April 2010, 11:56:14 »
If engine ecu, and you have previously said that your speedo doesn't work, then that points to your abs ecu being knackered
Zhing1
« Reply #5 on: 24 April 2010, 04:07:57 »
Do you think i should get a new abs ecu?
