Author Topic: Check Warning - Not in Manual- What does it mean?  (Read 3287 times)
Re: Check Warning - Not in Manual- What does it mean?
« Reply #15 on: 26 April 2010, 16:44:09 »
Does anyone know how a replacement sensor is supplied? Seems to be several parts, A piece fixed to the wishbone, a connector (The bit that keeps popping off) that plugs between the first part and the rear of the wired plastic plug.
Sorry for being a bit dim about this. I'm not the most experienced machanic as you can see.
Supplied complete I believe...
« Reply #16 on: 26 April 2010, 16:44:54 »
Thats the normal one where a wire has rubbed through, normally within a few inches of the ecu itself
Where is the HL levelling ECU? Not sure I've ever come across it. :-[
« Reply #17 on: 26 April 2010, 16:46:41 »
drivers wheelarch liner off :y
I'll try to get some pics later :y
« Reply #18 on: 26 April 2010, 17:25:54 »
Ahh, OK. That's why I've never found it. No problem. I'll have a look on TIS.
    • 530D M Sport, 330i Coupe
« Reply #19 on: 26 April 2010, 17:43:01 »
Yep was the case on mine, wire, solder and heat shrink tubing are your friends!  :y
I also wrapped the loom up with a couple of layers of insulating tape to try and prevent a re-occurance as it seems to rub on the arch liner.
Alex W
    • 2000W Facelift 2.5V6 Elit
« Reply #20 on: 26 April 2010, 18:27:26 »
Another question I'm afraid. What is the correct name for this sensor?
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #21 on: 26 April 2010, 19:19:21 »
headlamp level sensor pt number(from another thread here)
093197245
other rides
