Pages: [1] 2 3  All   Go Down
Author Topic: Exhaust Manifold Gasket  (Read 4949 times)
eliteomegaman
  • Bolton, Lancashire
  • if it aint broke dont fix it....
« on: 04 May 2010, 09:19:50 »
Morning all  :)
Have posted a few times about my facelift 2.5 elite with a misfire.
Just to re-cap -:
NOTHING showing on paper clip test or Tech 2
Coil pack replaced
Cam shaft sensor replaced (mechanic said fault code shown on tech 2 BUT didn't realise that the engine had to be running for it to clear!)
New spark plugs replaced
New HT Leads replaced (correctly fitted onto coil pack & no leads loose)
New fuel filter fitted
Compression test done y/day but nothing found!
Have now been advised that it could well be that the Exhaust Manifold Gasket could be the problem OR injectors (although 2 lots of cleaner where put in a couple of months ago when the problem first happened).
The exhaust does sound as if its blowing & i just wanted to ask anyone out there if they think that this could well be the cause of the bad misfire & if so is it an expensive job to do (i know the gaskets are only a few quid on ebay) labour wise?
I'm at the end of my tether with this & it's cost me a small fortune up to know which has completely made me skint!! :'(
PLEASE HELP!!!! :( :( :(
Re: Exhaust Manifold Gasket
« Reply #1 on: 04 May 2010, 09:22:42 »
Morning all  :)
Just to re-cap -:
Coil pack replaced
Don't get the cheap Ebay ones, only use the multi layer genuine Vauxhall ones from a dealer ;)
eliteomegaman
« Reply #2 on: 04 May 2010, 09:47:07 »
Cheers for the message Pete & the quote
All i can say is J-E-S-U-S didn't realise it was so expensive  :'( :'( :'(!!!!
Could the misfire be caused by the Exhaust Manifold Gasket leaking???
V6Astra F
  • Heidelberg , South Africa
  • 3.2 V6 Powered Kadett
« Reply #3 on: 04 May 2010, 09:55:39 »
Also had quite a random missfire when starting the car when it was still hot , turned out to be the MAF sensor as soon as I unplugged it the car ran fine
« Reply #4 on: 04 May 2010, 10:00:00 »
I would say no and given what your mechanics has changed....its time for a new mechanic!
eliteomegaman
« Reply #5 on: 04 May 2010, 10:27:38 »
[/highlight]
Trouble is i have a car that's misfiring & 3 different people don't know what the problem is & can only guess what it might be - plugs? renewed, ht leads? renewed, compression test? done, fuel filter? done, loose lead on coil pack? nope, paper clip test? done with nothing showing & the list goes on!!!
If it is the Exhaust Manifold Gasket then at an estimated £170 i'm f**ked cos not got a pot to p**s in!!!!
Maybe some-one on this site has had the same problem & could give me advise as i'm not mechanically minded  :-[
eliteomegaman
« Reply #6 on: 04 May 2010, 10:30:18 »
My misfire is there all the time as soon as i accelerate  :'(
« Reply #7 on: 04 May 2010, 10:31:11 »
You say the cam sensor was replaced (strange), do you mean the crank sensor?
V6Astra F
« Reply #8 on: 04 May 2010, 11:08:10 »
Mine had the missfire/stuttering from 1800-2700 rpm also with no eml light or codes stored . Just unplug it and go for a test drive .
eliteomegaman
« Reply #9 on: 04 May 2010, 11:10:16 »
Sorry ur dead right i mean the crank sensor code 31  :-[
« Reply #10 on: 04 May 2010, 11:11:01 »
Sorry you are dead right i mean the crank sensor code 31  :-[
Code 31 is normal when the engine is not running, code 19 indicates crank sensor failure.
Hope you did not replace it based on 31 code!
eliteomegaman
« Reply #11 on: 04 May 2010, 11:12:39 »
[/highlight]
How do i do that?
eliteomegaman
« Reply #12 on: 04 May 2010, 11:16:19 »
[/highlight]
YES!!!! My mechanic replaced it  :-? not knowing that on the tech 2 test code 31 shows untill the engine is fired up - when i told him he didn't charge me for his embarrasment  ;D
« Reply #13 on: 04 May 2010, 11:17:11 »
[/highlight]
How do i do that?
Unplug MAF sensor :)
« Reply #14 on: 04 May 2010, 11:17:30 »
[/highlight]
I would change your mechanic  :y
Pages: [1] 2 3  All   Go Up
Page created in 0.014 seconds with 14 queries.
