Author Topic: Found oil leak and coolant leak, need help !!!!  (Read 1659 times)
Jim
  • Glasgow
    • Irmscher 3.2 V6 Elite
    • My Vauxhall Omega's
« on: 05 May 2010, 23:11:42 »
I steam cleaned the engine a few days ago on the 3.2 and started it up today to try and find the leak and it looks like its coming from a switch/sensor, but I don't know the name of the sensor, can anyone tell me??. pics below
I also found a coolant leak on the top of the radiator, its a small crack but enough to lose a lot of coolant from:
And the coolant leak:
« Last Edit: 05 May 2010, 23:17:28 by jim »
manny
  • bromorough.Wirral.
Re: Found oil leak and coolant leak, need help !!!!
« Reply #1 on: 05 May 2010, 23:15:51 »
oil pressure switch
2001 OMEGA MV6
Jim
  • Glasgow
« Reply #2 on: 05 May 2010, 23:18:52 »
oil pressure switch
OK, is it easy to change for a new one
manny
« Reply #3 on: 05 May 2010, 23:28:33 »
Never done one but im sure you just unplug it and get bit spanner on it.
2001 OMEGA MV6
tidla
  • solihull
« Reply #4 on: 05 May 2010, 23:51:09 »
had a couple off beers, cant tell whether its my eyes or your photo :o
« Reply #5 on: 06 May 2010, 01:45:15 »
Top of rad - if crack/hole small try sealing it with a soldering iron :y
Kaycee
  • Doncaster
« Reply #6 on: 06 May 2010, 07:00:13 »
switches 5.40 on tc 24 mil spanner 30nm dont overtighten its ally 5 nin job
i too have leak from there but after 3 or 4 switches and varios washers  there is still a leak from there well that region but its not switch i had to have mine helicoiled as garage tightened it till it stripped
There is a tide in the affairs of man if taken at the flood will lead on to greater things
Jim
  • Glasgow
« Reply #7 on: 06 May 2010, 09:23:59 »
I took the photos on my mobile phone so the focus isn't 100% ::)
Jim
  • Glasgow
« Reply #8 on: 06 May 2010, 09:24:48 »
Good idea :y
Jim
  • Glasgow
« Reply #9 on: 06 May 2010, 09:25:49 »
Cheers Mate!!
kcl
  • Finland
    • Volvo V60 D4 -14
« Reply #10 on: 06 May 2010, 11:14:12 »
There's no need for washers, the thread is conical IIRC. Also, the leak is usually from the joint between the inner part (sensor itself) and the threaded part, so any kind of gasket/sealant will not cure the problem...
Kaycee
  • Doncaster
« Reply #11 on: 06 May 2010, 13:28:05 »
im afraid to say that its not conical and it comes complete with a ally crushable whasher i ended up putting a leather washer on mine but as stated my leak is from elsewere as i put a rubber sleeve on mine to find out there was oil on the outside of rubber but non underneath so switch is out of the equation
Kaycee
  • Doncaster
« Reply #12 on: 06 May 2010, 16:05:56 »
As an aside its best with a deep 24 mil socket you can get to it without taking bagpipes out but as your leak looks black oil i would say yours is the switch as my leak is clean oil but when ive took the switch out the oil that comes out is very dark coloured like yours
Jim
  • Glasgow
« Reply #13 on: 06 May 2010, 16:39:19 »
After cleaning the engine it was easy to see that the oil was coming from the switch, have ordered one from local dealer which I collect tomorrow :y
Page created in 0.039 seconds with 20 queries.
