Author Topic: 3.2 rough idle  (Read 1320 times)
3.2 rough idle
« on: 09 May 2010, 11:41:15 »
A member has a (pretty rapid) 3.2 that runs fine, except at idle.
A few seconds after dropping to idle, it starts to miss badly, then throws 1/3/5 cyl misfires (P0301, P0303, P0305, P0300).
Initial reaction was that the lamdas were incorrectly connected (car does have history of a fair amount of work being done on it), possibly crossed between banks. Proved to be connected correctly by unplugging 3 of the 4 in turn, whilst watching live data.
Not tested myself, but compression alledgedly good on 1/3/5, 2/4/6 not checked.  Coil pack also replaced with known good one.
Car is absolutely find above about 1000rpm, and owner says fine on cold start.
Worth taking a punt, and replacing front lamdas?  :-/
Re: 3.2 rough idle
« Reply #1 on: 09 May 2010, 12:03:42 »
has 1,3,5 wiring to coil pac been checked? or are we beyond that now? although would think symptoms would be more random than is evident....
Re: 3.2 rough idle
« Reply #2 on: 09 May 2010, 12:43:47 »
Not metered out, as the car shows no lack of performance.
Re: 3.2 rough idle
« Reply #3 on: 09 May 2010, 12:44:21 »
1/3/5 coil pack is known good removed from another 3.2 which had no engine issues.
Re: 3.2 rough idle
« Reply #4 on: 09 May 2010, 12:58:32 »
Should also say, although my V6 locking kit is on loan, we did visually check cambelt timing, and it looked pretty good, so think we can rule that out - if it is out, its not by enough to make it idle as badly as it does....
Re: 3.2 rough idle
« Reply #5 on: 09 May 2010, 14:09:22 »
got any 2.6 bits you can swap to it?
air leek in exhaust?
beyond me tbh.
    • 530D M Sport, 330i Coupe
Re: 3.2 rough idle
« Reply #6 on: 09 May 2010, 14:57:35 »
Think it's worth trying another dis-pack on that bank and checking the wiring to that pack.
Re: 3.2 rough idle
« Reply #7 on: 09 May 2010, 15:04:06 »
Coil Pack already swapped with another car. Fault stayed with car, not coil pack.  Wiring, yes, thought about that, but it runs so well above idle.
jumplead from battery to the lifting eye that side makes no difference, so ruled out earths....
Re: 3.2 rough idle
« Reply #8 on: 09 May 2010, 16:33:57 »
I know it's been serviced but is it worth popping the plugs out and swapping them for another set?
Re: 3.2 rough idle
« Reply #9 on: 09 May 2010, 16:36:52 »
Alledgedly the plugs that side have already been done
Re: 3.2 rough idle
« Reply #10 on: 09 May 2010, 16:38:17 »
Who's to say that one hasn't got a problem even if it's new?
Had a similar problem with a cavalier, the insulator ceramic was cracked.
