Author Topic: Diesel engines  (Read 1681 times)
Diesel engines
« on: 09 May 2010, 22:24:03 »
Are there 2 engines, a 2.2 and a 2.5? seen a couple of 2.2's on ebay :-/
If there is which is best?
BHP of each?
tidla
  • solihull
Re: Diesel engines
« Reply #1 on: 09 May 2010, 22:58:22 »
2.2 is the vauxhall lump. 2.5  is the straight 6 is bmw derived lump. :)
Re: Diesel engines
« Reply #2 on: 09 May 2010, 23:10:32 »
Guess the 2.5 BMW lump is the best one then.... :)
Agemo
  • Cleethorpes
  • Insignia
Re: Diesel engines
« Reply #3 on: 09 May 2010, 23:13:22 »
2.5TD has a "Massive" 96 BHP @ 4,500 RPM.   ::)
Re: Diesel engines
« Reply #4 on: 09 May 2010, 23:35:45 »
Is that all :o, seen them advertised with 128 or therabouts, what is the 2.2, any idea..... :(
tidla
  • solihull
Re: Diesel engines
« Reply #5 on: 09 May 2010, 23:39:29 »
all the numbers you need, wont help a jot thou ::)
http://en.wikipedia.org/wiki/Opel_Omega
88kw
Re: Diesel engines
« Reply #6 on: 09 May 2010, 23:56:35 »
X20DTH 2.0 DTI 16V I4 101 PS (74 kW; 100 hp) 205 N·m (151 lb·ft) MY 1998-2000
Y22DTH 2.2 DTI 16V I4 120 PS (88 kW; 118 hp) 280 N·m (207 lb·ft) MY 2000-2003
X25DT 2.5 TD I6 131 PS (96 kW; 129 hp) 250 N·m (184 lb·ft) MY 1994-2000
Y25DT 2.5 DTI I6 150 PS (110 kW; 148 hp) 300 N·m (221 lb·ft) MY 2001-2003
So these are the ones to look out for, 129 is not much is it, less that a 2.0l petrol, and in auto that is not exactly quick....... :-/
joshwyatt
  • Oxford
Re: Diesel engines
« Reply #7 on: 10 May 2010, 00:10:02 »
Have a quick look at this quide I produced, got a bit about the 2.2 DTI...
http://www.omegaowners.com/forum/YaBB.pl?num=1266867411
However, I remember one of your stipulations for a new car is that it must be auto. The 2.2 DTI only comes in manual. And the 2.5 TD ceased on a 'Y' plate. You tend to find more pre and mini fl's with the 2.5 really.
joshwyatt
  • Oxford
Re: Diesel engines
« Reply #8 on: 10 May 2010, 00:11:34 »
The 2.5 DTI, was not available in the UK, so you'll only be looking at the 129bhp TD model.
Re: Diesel engines
« Reply #9 on: 10 May 2010, 08:30:14 »
Why is that then, its only a badge ;)
Stock form, the 2.2 is more powerful, but only available in manual.
The 2.5 is easily chipped back to BMW spec (and beyond), but if you have an auto, you'll need to change the gearbox.  I think the manual box is better suited to this engine though...
Both have their fair share of issues (usually around damage/wear caused by previous, inadequate servicing).
My own personal preference would be for the 2.5TD.  Sadly, Vauxhall did not get the Y25DT engine.
tidla
  • solihull
