Pages: 1 ... 18 19 20 21 22 23 24 [25] 26 27 28 29 30 31 32 ... 42   Go Down
Author Topic: Engine noise, terminal?  (Read 117698 times)
0 Members and 3 Guests are viewing this topic.
Re: Engine noise, terminal?
« Reply #360 on: 25 March 2010, 10:12:18 »
Well I found a crack in the manifold to EGR pipe....
ooooh, would be nice if it was that, right area, but....i reckon the noise is too loud and knocky for that, exhaust is usually "futty" ime, but here's hoping.
Indeed but, needs ruling out as clearly its a fault  :y
The optimist in me says that whilst the gas leak might not have caused the noise we heard, perhaps the EGR valve was getting a battering as a result due to lack of back pressure between exhaust events. :-/
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #361 on: 25 March 2010, 12:20:43 »
And might account for the lack of 'clank' while only cranking :-/
« Reply #362 on: 25 March 2010, 19:08:12 »
My gut feeling is the crack on egr pipe would sound more like a failing exhaust manifold gasket, rather than noise I thought it was?
But here's hoping :D
what about the 'stiffer' exhaust valves on pot 1 ?
  • Auckland
    • Mazda MPV
« Reply #363 on: 25 March 2010, 20:26:45 »
Has your MV6 got EGR?
Is the nut on the flexible pipe done up properly?
Your initial comment about the noise being more rapid than a sticky lifter makes me wonder if it isn't caused by exhaust pulses making giving something a hammering :-/
I don't remember getting an answer to that question :P
I did get an answer (but I forgot :()
« Last Edit: 25 March 2010, 20:30:20 by andyh »
« Reply #364 on: 25 March 2010, 21:27:06 »
The nut holding pipe to egr valve was done up correctly several times by myself
Shackeng
  • Ramsbury
« Reply #365 on: 27 March 2010, 19:00:07 »
Please please please, what's happening? :P :P :P
« Reply #366 on: 27 March 2010, 19:07:01 »
suspect The Master has his feet up with a well earned beer after a days hard training...
« Reply #367 on: 27 March 2010, 19:15:07 »
TB,  you can have a free lift to Silver bullets holiday resort, in exchange for some muscle to rotate my lpg tank  8-)
« Last Edit: 27 March 2010, 19:15:19 by tunnie »
cleggy
« Reply #368 on: 27 March 2010, 19:23:46 »
I know, I can't wait much longer the suspense is tooooo much, all I want to see is a happy outcome. Better than a TV drama you couldn't script this saga. come on guys  :y
« Reply #369 on: 27 March 2010, 22:38:51 »
Make sure you don't pull on the Gas Tight Box... It'll break and you have to remove the multivalve to replace it :o :o :y
[edit]I'll re-word that... Make sure TB doesn't pull on the box, he'll break it. You probably wouldn't have the strength ;D ;D[/edit]
« Last Edit: 27 March 2010, 22:40:09 by Lazydocker »
« Reply #370 on: 30 March 2010, 09:51:50 »
Has the EGR fault been tested/ruled out yet? ::)
« Reply #371 on: 30 March 2010, 10:09:23 »
what happened.. why nobody say anything :-/
loosing my patience here ;D
« Reply #372 on: 30 March 2010, 12:04:56 »
poor Mark, bless him. Whole forum pestering him, and TB with out his beloved car. Praying to God i havent caused all this agro.
« Reply #373 on: 30 March 2010, 12:14:10 »
I am going to put it all back together tonight and go for a start-up.....then some T2 tests.
« Reply #374 on: 30 March 2010, 13:09:30 »
living on the olympos not easy.. the mortals will always disturb you ;D
Pages: 1 ... 18 19 20 21 22 23 24 [25] 26 27 28 29 30 31 32 ... 42   Go Up
