Author Topic: V6 Head Gasket Longeivety  (Read 2988 times)
Re: V6 Head Gasket Longeivety
« Reply #15 on: 14 May 2010, 15:56:06 »
Sounds like you've already made you mind up James ::)
Not necessarily - but, while it's half way apart, I just wonder whether it's worth doing the extra things, like manifold gaskets, stat, etc....
;D ;D ;D
James' don't think i'm being nasty, i'm not, but from my observations every car you've had you stripped down rebuilt and them prompty sold it. Now I don't know but would think that you may have lost or possibly broken even on these cars so why not wait a while, decide if its the car for you to keep and then consider rebuilding it ;)
Your observations are correct - with a couple of very rare exceptions, I have always lost out on cars.
You know what, I don't know what it is... I take great satisfaction from stripping down a V6 and getting everything spot on.... and after I've done so, I seem to get bored and look for another project  :-[
I'm the same with the getting bored bit but luckily I keep an eye on how much I spend and what the cars worth. I have 3 Omega's here, the 3.2 estate is done and up for sale the other is a lovely 3.0 facelift black elite and the 2.5 manual facelift diesel. I can only keep one and its probably swayed between each one everyday of the week ;D ;D
« Reply #16 on: 14 May 2010, 16:06:20 »
If engine really is solid, and coolant maintenance seems to be OK, my time and money may just be better spent on the LPG, being honest..
« Reply #17 on: 14 May 2010, 16:09:09 »
Spend the difference on taking Maria out and earn some brownie points:y
« Reply #18 on: 14 May 2010, 16:11:21 »
I've still got a few brownie points in the bank, from 2 trips to Ibiza and 1 trip to Amsterdam this year  :D But yes, it could also be used for the numerous camping trips we will no doubt undertake this year  :y
« Reply #19 on: 14 May 2010, 16:15:05 »
Will Lakes and Newent (for more than 2 minutes ;)) feature on the camping trail this year?
« Reply #20 on: 14 May 2010, 16:26:04 »
Most definately, you cheeky barsteward...  :y
Sixstring
  • Lydney, Gloucestershire
« Reply #21 on: 14 May 2010, 16:54:56 »
James...
Bearing in mind mines done 151k now, had the cambelt and tensioners, water pump, cam cover gaskets, those sh*tty pipe dowty washers (remember....)HBV, now wishbones, droplinks, tie rods, steering arms, exhaust, oil, filter, fuel filter, 4 tyres, and I've only had it 12 weeks...............and does 33 on a run, don't you think you ought to leave it alone for a bit and do it ALL when you do the LPG kit and start from a level playing field???
« Reply #22 on: 14 May 2010, 17:10:12 »
Yep, I agree....
I was going to do the coversion over the next 2 weekends  ;D :y
bertiecbx550
« Reply #23 on: 14 May 2010, 17:19:30 »
Yes james imho do the jobs that will give you peace of mind and hopefully by then i will have the dosh off the sale of the house to buy it off you when you get bored of it.... ::) ::) ::)  ;D ;D ;)
« Reply #24 on: 14 May 2010, 17:38:40 »
James, if you're going to do the HG (which I wouldn't unless it had definitely failed, TBH) then don't actually fit the LPG until you've had it running and checked for any potential pitfalls... By all means put a loop of coolant hose in but I wouldn't go any further than that. All you do is introduce more things to check if there's a problem ;)
Martin_1962
« Reply #25 on: 14 May 2010, 19:35:59 »
What about the exhaust manifolds?
jb
  • bucks
    • 3.2 Elite
« Reply #26 on: 15 May 2010, 10:42:16 »
my experience is that if its running well and the cambelt kit has been done on schedule leave well alone - hg failure v rare and usually down to poor coolant renewal regime........
