Author Topic: Oil filter housing torque value  (Read 1795 times)
gsizoli
  • Hungary
« on: 18 May 2010, 14:15:58 »
HI!
I can't find information about the torque value of the oil filter housing for later V6 motors.A huge HEX bolt fixes the house to the cylinder block.Does anybody know this value?So I need the torque value for the whole house (bolt) not the house cover.
Br
Zoli
Re: Oil filter housing torque value
« Reply #1 on: 18 May 2010, 16:30:01 »
Absolutely no more than 15nm!! :D ;)
All too often they are over tightened, and in truth just a light tightening is actually required. :y :y
tidla
  • solihull
« Reply #2 on: 18 May 2010, 16:45:20 »
thats the cover cap, he wants the whole housing to block bolt torque. :)
« Reply #3 on: 18 May 2010, 16:53:01 »
Ah, sorry!  25Nm is that torque :D :D ;)
gsizoli
  • Hungary
« Reply #4 on: 18 May 2010, 19:45:33 »
Thanks. :)
TestOmega
  • Mississauga, Canada
  • Been helped, will help.
« Reply #5 on: 21 May 2010, 01:55:04 »
HI!
Br
Zoli
If it helps from my Notes on the 2001 Cadillac Catera V6 3.0L
  - The bolt that holds the housing to the block needs a 12mm hex head (allen key) bit to remove/ replace it. The bolt is hollow so don't lose anything inside it!
  -  33ft/pounds or 45 NM for the filter housing
  -  and 11ft/pounds or 15 NM for the cap.  The cover/ cap is shaped to take a 24mm socket.
Additionally, Torx size for sump drain plug: T40
Cheers
!!!!!!!!!!!!!!!!!!  May I be blessed to give more than I receive  !!!!!!!!!!!!!!!!!!
