Author Topic: V6 spark plug torque wrench value pls?  (Read 1257 times)
Varche
  • middle of Andalucia
    • Golf Estate
« on: 15 May 2010, 15:29:13 »
Can't find it anywhere in my Haynes!
Re: V6 spark plug torque wrench value pls?
« Reply #1 on: 15 May 2010, 16:02:41 »
http://www.google.co.uk/search?hl=en&as_q=spark+plug+torque+wrench&as_epq=&as_oq=&as_eq=&num=100&lr=&as_filetype=&ft=i&as_sitesearch=http%3A%2F%2Fwww.omegaowners.com%2Fforum%2FYaBB.pl%3Fboard%3Dgeneral&as_qdr=all&as_rights=&as_occt=any&cr=&as_nlo=&as_nhi=&safe=images
Have a nosy through these. :y  But please double check the quote below.
The spark plugs were torqued with a torque wrench to 25NM. I also noticed that the wrench ‘broke’ exactly after 1/4 turn from pressure applying point – which is what it should do.
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
« Reply #2 on: 15 May 2010, 18:10:10 »
Spark plugs . . 25Nm 18lbf ft
From the table in Chapter 1.
TuBy's new whipping boy.
TestOmega
  • Mississauga, Canada
  • Been helped, will help.
« Reply #3 on: 21 May 2010, 02:45:58 »
2001 Cadillac Catera V6 3.0L GM spec is 18 Ft Lbs or 25 NM as alluded to by the friend above.
Cheers.
!!!!!!!!!!!!!!!!!!  May I be blessed to give more than I receive  !!!!!!!!!!!!!!!!!!
