Author Topic: Code 59 ......  (Read 877 times)
I_want_an_Omega
Code 59 ......
« on: 28 May 2010, 10:41:33 »
Hi,
I'm getting a "fast flickering" ECU light.
Turns out its a Code 59 - which is:
59   Intake Manifold Valve 1 Voltage Low
I think this is the rear multiram control valve - but any ideas?
It's only started doing it today and that was after I opened her up after a cold start. The light now comes on as soon as the car is started & its defo flickering - with the light being on 95% on and 5% off.
I've had the plenum off to the the cam covers so suspect that I might have disturbed something.
Thanks
Re: Code 59 ......
« Reply #1 on: 28 May 2010, 11:51:20 »
Valve 1 is the rear one, correct.
If you've had plenum off, its an easy one to forget to plug back in.  I'm sure we all have at some point  :-[
Omegafantasy
  • Oslo, Norway
Re: Code 59 ......
« Reply #2 on: 28 May 2010, 12:01:18 »
A voltage low error would be a short circuit as far as I know. If it was disconnected he would get a "voltage high" error.
Please correct me if I'm wrong, but that's my experience and logic so far.
1995 Omega 2.6 V6 Estate ("fresh" engine) Drives like a 2-litre. Grr! Gettin' dusted by a 1.8 auto Cav..
1991 Omega 3000-24v (major rust job)
(Interested in buying Vauxhall emblems/grille for my V6)
Re: Code 59 ......
« Reply #3 on: 28 May 2010, 12:05:42 »
Not necessarily, but would need to check it...
Re: Code 59 ......
« Reply #4 on: 28 May 2010, 12:22:53 »
I think the low side of the solenoids are switched by the ECU so voltage low = disconnected.
(ECU expects 12v on the line, grounds it to energise solenoid).
I_want_an_Omega
Re: Code 59 ......
« Reply #5 on: 28 May 2010, 12:44:24 »
Thanks guys, will take a look & let you know ,,,,,,,,,,,,
