Author Topic: Removing the rubbing strips  (Read 955 times)
« on: 29 May 2010, 20:33:09 »
Anyone know how to remove the rubbing strips on the front wing on facelifts, without damaging?
Re: Removing the rubbing strips
« Reply #1 on: 29 May 2010, 20:39:06 »
remove side indicator lamp, behind arch liner 10mm bolt holds it on
« Reply #2 on: 29 May 2010, 20:42:04 »
Cheers - how does the indicator come out, prised out?
« Reply #3 on: 29 May 2010, 20:43:21 »
Yep,
« Reply #4 on: 30 May 2010, 17:09:42 »
Cheers RobG, all nicely removed.  Had to remove charcoal cannister on drivers side, and relay box cooling fan on passenger side :y
« Reply #5 on: 30 May 2010, 18:12:02 »
Surprised Sammy hadn't helped already ::) ::)
Still got the Golden Nugget on the drive then?
