Author Topic: Cat removal advice  (Read 3475 times)
Re: Cat removal advice
« Reply #15 on: 28 May 2010, 21:42:29 »
soak the exhaust manifold studs in WD40, i've had no problem doing x2 2.2's they release fine. Exhaust bolts could be an issue, again soak well in WD, if you do end up drilling them out, use decent quality ones cause cheap ones will snap off then it will take you 10 times as long drilling them out.  :y
Raymienets
  • Glasgow
    • 2.2 cd & 2.6 LPG
« Reply #16 on: 28 May 2010, 22:38:28 »
Cheers will give it a go. already snapped one at exhaust . someone said wd40 wouldnt work in an earlier post.
« Reply #17 on: 28 May 2010, 23:22:16 »
WD is not a penetrating oil, no doubt someone can confirm something that would work better. But from personal experience on doing two of these jobs, its better than nothing!
« Reply #18 on: 28 May 2010, 23:25:37 »
Raymienets
  • Glasgow
    • 2.2 cd & 2.6 LPG
« Reply #19 on: 01 June 2010, 17:27:06 »
Plusgas http://www.toologics.co.uk/img/product_l/PLG801l.jpg
Ordered many thanks for the advice.
« Reply #20 on: 01 June 2010, 21:42:10 »
WD40 is not a patch on plusgas, but will help is soaked on regularly for a few days before removal...
Raymienets
  • Glasgow
    • 2.2 cd & 2.6 LPG
« Reply #21 on: 01 June 2010, 22:23:52 »
Does Plusgas work quickly or do I need to leave it for a few days spraying daily.
Matchless
  • Nottingham
    • A white van
« Reply #22 on: 02 June 2010, 13:42:12 »
I fitted a clamp-on flexible section to a previous 2.0, bought off ebay.
There wasnt much pipe length to play with but I cut the old section out with an angle grinder in-situ, leaving as much pipe as possible and then clamped on the new section with exhaust paste.
Always meant to weld it up next time the gearbox was off (dont ask) but it lasted for 3 or 4 years till I sold it on.
