Author Topic: Coolant Level  (Read 3519 times)
megaomega123
Re: Coolant Level
« Reply #15 on: 03 June 2010, 10:02:19 »
Hi I'm also loosing coolant but I think its coming from what looks like an electric valve under the header tank. This makes what sounds like a washing machine draining when turning on the ignition. This is a 96 pre face lift. What is it?
I think you should start a new post with specific details of your issue as it sounds completely different to hbv.
I think you will get better advice this way  :y
Tony O
  • Ormesby, Great Yarmouth
Re: Coolant Level
« Reply #16 on: 04 June 2010, 08:23:09 »
Think I might change the hbv & see if that sorts problem first if not I'll be back ( as Arnie would say).
Tony O
Re: Coolant Level
« Reply #17 on: 06 June 2010, 09:53:18 »
Changed hbv was leaking. Took about an hour and no cuts, result. Thanks again guys.
