Author Topic: ignition barrell jammed  (Read 2570 times)
Re: ignition barrell jammed
« Reply #15 on: 07 June 2010, 16:34:12 »
Spray a bit of the (over rated) WD40 in to the barrel and leave for a few minutes
Insert and remove the key 10-20 times.
Try again
Oi! It has its uses. Its quite good for bringing plastics back to black ;D ;D ;D
.. until it rains again. ::)
I find it's excellent for stopping lawn mowers rusting.
If you have to use it on a lock I'd say regard it as an emergency measure as the sticky residue will collect any future contaminants. Best to refurb the lock afterwards and lubricate with something dry like graphite IMHO.
fergy
  • Hereford
  • 2001 CDX 2.2dti Estate
« Reply #16 on: 07 June 2010, 17:57:49 »
Lots of advice here buts should you need to drill it here is my learning:
New lock requires car pass presented to VX dealer.
Order early in the day and it is likely to be available next day. (I did post something about VX's supplier of the lock on this forum,  a firm in N. London as far as I can remember)
Carefully prize off and remove the rubber surround to the ignition key barrel.
Carefully prise apart steering lock plastic cover along RH join, it clips together but is also held on by two self tappers behind the steering wheel. This will enable you to gain a bit of movement in the cover ready to attack the screws.
By moving the now wobbly cover around you should just be able to get a small cranked pozi drive driver to the heads of the two self tappers (after prizing off their caps)
Once you have got this far and the cover is fully removed, it is a question of drilling the lock out.  Suggest using increasing sized drills being careful not to go too deep, and holding drill in alignment with where ignition key would be. Standing on your head in the car seat,  the depth required becomes fairly obvious! The lock is made of some kind of cast alloy (wards are brass) and drills fairly easily, but makes a mess of the carpet, so put something down first.
Once old barrel is out, replacement with new is easy.  Use the "How To" to identify parts and  method. If  new barrel does not go straight in and latch in place, it is probably because the steering lock has engaged. ( see also how to  or reminder packed with replacement barrell)
 Best of luck
Hannah Judes Dad
    • the misses round the bend
« Reply #17 on: 07 June 2010, 21:38:51 »
My lock was causing a bit of grief earlier and no matter how much jiggling of the key it wouldn't turn,in the end it was solved by making sure I had pushed the key into the lock firmly and all is ok for the moment (touch wood)
