Pages: 1 [2] 3  All   Go Down
Author Topic: Vented rear discs?  (Read 5080 times)
Re: Vented rear discs?
« Reply #15 on: 07 June 2010, 21:01:20 »
So can i assume my lowly 2.2 will have solids then .
I can go and whip the wheel of and check but its pouring down outside .
Im just about to buy some rear discs but now i better check first  :y
Yep. With the rears genuine aren`t necessary, same as the pads & shoes
« Reply #16 on: 07 June 2010, 21:04:50 »
i have upgraded my rear discs to vented discs, and also the front to drilled and groved :).
vented and drilled + grooved are just to disperce heat more so you dont warp your disc :)
ANDY :y
Upraded? You sure? Certainly by fitting vented at the back, you've now upset the front - rear bias of the original design, the master cylinders are apparently different. Drilled grooved discs have no advantage on the road over original fitment ..... but they look good.  :y
andy broon
  • aberdeen
« Reply #17 on: 07 June 2010, 21:09:27 »
ANDY :y
yes i am sure well i am a mechanic and everything has been done ;) i just like black diamond so thats whats on all my cars lol i have a rear disc conversion of black diamond on my fiesta too :)
but my miggy was damaged today :(
ANDY :y
Shrek
  • Fife , Scotland
« Reply #18 on: 07 June 2010, 21:09:40 »
I have GM pads here anyway .
I'll get some ebay specials for the rear discs  :y
"My Naff Code Reader" and OBD2 readers available .
andy broon
  • aberdeen
« Reply #19 on: 07 June 2010, 21:11:42 »
was just looking on ebay for some more stuff for my miggy when i came across this well it was first in the list
enjoy :) http://cgi.ebay.co.uk/Omega-VENTED-REAR-Drilled-Grooved-Brake-Discs-94-03-/110485744366?cmd=ViewItem&pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item19b976aaee
« Reply #20 on: 07 June 2010, 21:14:31 »
I thought the vented rears used a different caliper :-?
andy broon
  • aberdeen
« Reply #21 on: 07 June 2010, 21:17:42 »
mah its all the same unless you are up grading the standard size of the disc :).
A :yNDY
Shrek
  • Fife , Scotland
« Reply #22 on: 07 June 2010, 21:20:12 »
A :yNDY
Wont a vented disc be wider than a solid and hence need a different caliper ?
andy broon
  • aberdeen
« Reply #23 on: 07 June 2010, 21:23:21 »
A :yNDY
no should all be the same size again unless upgradingbut if you are uprating discs to vented you would be getting the pads aswell so it always fits, because you wouldnt upgrade one without the other
ANDY :y
Shrek
  • Fife , Scotland
« Reply #24 on: 07 June 2010, 21:25:35 »
A :yNDY
ANDY :y
Ahh i didnt know that , learn something new every day  :y
« Reply #25 on: 07 June 2010, 21:28:30 »
A :yNDY
Yes.
Marks DTM Calibration
Administrator
Online
Ex Member
Gender:
  Re: Any idea what type calliper I have?
Reply #7 - 07. Oct 2009 at 21:51     chrisgixer wrote on 06. Oct 2009 at 22:29:
Marks DTM Calibration wrote on 06. Oct 2009 at 13:50:
SteveD wrote on 06. Oct 2009 at 11:13:
Me being lazy here....
I'm lead to believe my V reg facelift 3.0 Elite Estate could have either Lucas or some other make(can't remember at the mo.) of calliper on the front.
Does anybody know for definite which type it will be or do I have to take a look? If the only way to tell is from looking, does anyone have a couple of pics so I can tell without removing a wheel?
Thanks
Steve
Only one type of caliper ever fitted to the front of the V6's
And rear calipers are wider if vented discs on the rear as well as the front??? Some body asked the other day and couldn remember for sure.
Cant help with the make sorry. Dont remember much in the way of markings either tbh
Fairly obvious but, vented discs are wider than solid ones and hence require a larger caliper
« Last Edit: 07 June 2010, 21:29:05 by RobG »
andy broon
  • aberdeen
« Reply #26 on: 07 June 2010, 21:28:41 »
A :yNDY
ANDY :y
we all learn somthing :) like i learnt that i hate polish bikers
ANDY  :y
« Reply #27 on: 07 June 2010, 21:30:36 »
A :yNDY
ANDY :y
I'm with Shrek. Vented discs will HAVE to have a wider caliper, or you'll have vented discs the overall thickness of solid discs .... 12/13mm??  :-/
« Reply #28 on: 07 June 2010, 21:34:05 »
A :yNDY
ANDY :y
Correct
« Reply #29 on: 07 June 2010, 21:41:03 »
Correct  ....
I know  ;)  ;)  ;)
IIRC they used to fit Princess vented discs to the front of Capris. The Princess calipers fouled so they used the old Capri calipers with a spacer fitted between the two halves.
Pages: 1 [2] 3  All   Go Up
