Author Topic: ignition problem Please!!!!Please!!!! HELP!!!  (Read 4075 times)
same #same#
  • south yorks
  • dont blame me im dyslexic
Re: ignition problem Please!!!! HELP!!!
« Reply #15 on: 11 June 2010, 16:12:45 »
got to go now have a good rest of moving day. :y
Eric DUBLIN
  • DUBLIN
« Reply #16 on: 11 June 2010, 16:15:02 »
are you going from the back or the front??
front
can you get to it from behind with the end off the allankey bent end or bend somting to get to it made out of metal. :question
in after getin nit out yipppee oh man so exciting my adrenalin is flowin here im suppose to be outtahere on monday morning anyway whats next i have key and barrel in my hand
just need to remove the plug with the wires on should be easy from here, but pull toward you not out, then should be able to start with screw driver when got the plug off put the barrel back in to stop the lock engaging when get time change the wire plug should get you fixed for the day so yu can move :y dont put wire plug back on, and leve the key in alltime till fixed. :y
what plug???    by the way the brass shaft has broken just at the end of the spring
« Last Edit: 11 June 2010, 16:17:25 by goldrush »
charlie
  • sunderland
« Reply #17 on: 11 June 2010, 16:21:38 »
Have a look in the mantanice guide 2nd page,2nd from bottom eric, that should help alot :y :y
« Last Edit: 11 June 2010, 16:22:19 by charlie »
Eric DUBLIN
  • DUBLIN
« Reply #18 on: 11 June 2010, 16:23:24 »
      cheers man thanks to yerself and same same  nice'1 :y :y
Eric DUBLIN
  • DUBLIN
« Reply #19 on: 11 June 2010, 16:32:19 »
   it does and it dont if ya know what i mean im just tryin to  get mobile :-/
charlie
  • sunderland
« Reply #20 on: 11 June 2010, 16:35:45 »
has the thin bit of the ingition barrel snapped,thus not turning the black switch at the end
« Last Edit: 11 June 2010, 16:36:39 by charlie »
Eric DUBLIN
  • DUBLIN
« Reply #21 on: 11 June 2010, 16:53:21 »
  yes charlie  sorry for delay was out at the motor
« Last Edit: 11 June 2010, 16:56:41 by goldrush »
charlie
  • sunderland
Re: ignition problem Please!!!!Please!!!! HELP!!!
« Reply #22 on: 11 June 2010, 17:17:13 »
well take the switch off the end by the 1 screw put barrel back in(to take off steering lock and turn to poss 2) and manually turn switch (you may have to gentle push in the centre of the switch then turn)
Eric DUBLIN
  • DUBLIN
« Reply #23 on: 11 June 2010, 17:50:41 »
  on doing that the small black piece popped oout no worries other than the two contact spades vary one is longer, tried the start sequence but imobilizer orange light flashing????????
charlie
  • sunderland
« Reply #24 on: 11 June 2010, 17:56:22 »
when turning the switch you need the key very close to the ingition to keep the immobilizer happy(might as well have it in to take off steering lock)
« Last Edit: 11 June 2010, 18:02:02 by charlie »
Eric DUBLIN
  • DUBLIN
« Reply #25 on: 11 June 2010, 19:23:44 »
sound as  :y   thankyou man
