Author Topic: caravan advice....no i am not boring.  (Read 11551 times)
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
Re: caravan advice....no i am not boring.
« Reply #15 on: 09 June 2010, 00:37:25 »
Omega is without doubt the best towcar I've had, bar none.
+1,I have towed with many different cars and 4x4s and the mig is the best so far :y :y
other rides
russ b
  • dudley west midlands
« Reply #16 on: 09 June 2010, 00:40:29 »
i don't know what you mean by 3pin and 4 pin, sorry i am novice to all this.  :o
i thought that when you plugged in van that there was an audible/buzzer when indicators applied  :-/
is it true that length of van shouldn't exceed car length??
russ b
« Reply #17 on: 09 June 2010, 00:41:56 »
does anyone think that a section on towing and caravans should be started there seems to be strong feedback here and a bit of intel/interest?? :y :y
henryd
  • west cornwall
« Reply #18 on: 09 June 2010, 00:55:45 »
it can either be an audible buzzer or a tell tale lamp to show that the indicators on the trailer are operating
other rides
same #same#
  • south yorks
  • dont blame me im dyslexic
« Reply #19 on: 09 June 2010, 02:35:57 »
Hi i have 2.2 estate and my tow limit is 1600 kg so long the caravan is no more than 1600 kg laden .
Mine tows ok but some use spring assister's
Look in your manual should tell you your tow limit
tha hand book will tell you what the car is able to pull up a ??? degree slope, not what you're allowed to pull on the road.  ;)
In my manual it tells me my max braked towing limit is 1600 kg .And the max nose weight is 75 kg
Ive tested nose weight its about 80 kg and it rides level
have you a 5kg gas bottle in the front???
« Reply #20 on: 09 June 2010, 08:54:48 »
Unplug the flasher unit already fitted to the car, it's in the fusebox under the steering column, turn the indicators on & feel which relay is clicking. When you have unplugged it, you'll see that it had been plugged in with 3 pins/connectors. If you go into Halfords or elsewhere, you'll see that you can buy a flasher relay with an extra connector on in ie 4 - this is now what you want. Remove your dash, fit a lamp in the space that Vauxhall provided for a trailer tell tale and that's it. When you indicate with a trailer on, it can tell whether your trailer is indicating & flash the extra lamp in tandem. If the trailer indicator has failed, then the tell tale doesn't flash.
Or you can fit a crappy buzzer in the boot to tell you the same thing.   :y
Impact Pete
  • Derby
    • Elite V6 2.6 estate
    • Custom Flightcase manufacture
« Reply #21 on: 09 June 2010, 09:25:15 »
hi looking to get caravan in summer. would like to know what weight limit i have and any mods (sensible) to make car better towing vehicle. also i have noticed alot of pics here with migs pulling twin axles is this ok? i thought this was for 4x4s only oh and can someone give me some advice on wiring towbar up :y :y
There was also a change in what you can tow weight wise without the extra bit on your licence, there are a lot of younger caravaners blissfully unaware they are illegally towing on their licence.
http://www.direct.gov.uk/en/Motoring/DriverLicensing/CaravansTrailersCommercialVehicles/DG_4022564
www.impactcls.co.uk - Flight Case Manufacture
hoofing it
« Reply #22 on: 09 June 2010, 09:39:48 »
For the car towing limit look at the plate inside the drivers door (omega) this gives max axle loads+towing weights :y.
P.S. does your liscence allow you to tow over 750kg
« Reply #23 on: 09 June 2010, 09:44:08 »
It's not as cut & dried as that  :-/
http://www.direct.gov.uk/en/Motoring/DriverLicensing/CaravansTrailersCommercialVehicles/DG_10013073
russ b
« Reply #24 on: 09 June 2010, 09:45:29 »
where is this space on dash on a mini pre facelift and is there connection or wiring behind this to connect light.
have seen a nice van "abbey gt" about 17ft going for 300 notes  just needs new cushions 8-)
russ b
« Reply #25 on: 09 June 2010, 09:51:22 »
looking at that link above from andy if i buy a caravan that does not take overall "mam" above3.5t i should be ok...passed my test this year :-/
Impact Pete
  • Derby
« Reply #26 on: 09 June 2010, 09:55:47 »
I would be very careful, maybe even phone them to confirm all details, they were pulling them in by the dozen last year and drivers literally had to leave the caravans at the roadside, it's worth taking the additional part of the test.
It's easy to go over weight on a caravan, awning, gas, cups plates, water etc.. all adds up :o
hoofing it
« Reply #27 on: 09 June 2010, 09:58:46 »
If you passed your test last year you WILL have to sit the B+E test :(.there is no theory test for this.
russ b
« Reply #28 on: 09 June 2010, 10:07:33 »
anyone know how much this test is, and whats involved
Impact Pete
  • Derby
« Reply #29 on: 09 June 2010, 10:13:48 »
DSA B+E Test Fee is £115 April 2009.
BUT there are reversing round a corner with trailer etc, some courses are up to £170 for a days training! :o
