Author Topic: Creaking from front of car  (Read 4302 times)
pscocoa
  • Sandhurst Berkshire
    • Volvo V90 D5 & Grandland
« on: 09 June 2010, 20:46:55 »
Here we go - could be anything - wishbones, drop links, bushes....
Re: Creaking from front of car
« Reply #1 on: 09 June 2010, 20:52:34 »
Arthritic joints :D
Is it just from cold or all the time :question
« Last Edit: 09 June 2010, 20:54:23 by RobG »
sjc
  • Alloa, Scotland
    • Ultra-dull Audi TDi
« Reply #2 on: 09 June 2010, 20:56:33 »
Is it over bumps or when turning the wheel (could be dry top mounting)
viking6152
« Reply #3 on: 09 June 2010, 20:58:06 »
It might help, but i used to have a Volvo S80 which had a creaking from the front offside, took me ages to find it.........and it was the bonnet catches which locked the bonnet in place when closed. ::)
[img]http://animated-gifs.eu/transportation-police/0023.gif
sjc
  • Alloa, Scotland
« Reply #4 on: 09 June 2010, 21:04:16 »
That's an odd one!  Bet that took ages to find  ::)
viking6152
« Reply #5 on: 09 June 2010, 21:07:05 »
Yeah, drove me nuts, and only creaked when i went over a bump! The screws had come  loose which hold the catc :(hes onto the bonnet!
pscocoa
« Reply #6 on: 09 June 2010, 21:09:41 »
 the creaking is all the time - I had not noticed it but my wife has been using the car this week and of course reports all faults. Went out and had a good push down (on the car) and creaking seems to be from under the engine - in car it sounds from drivers side wheel arch but from front of car with bonnet up is in centre
sjc
  • Alloa, Scotland
« Reply #7 on: 09 June 2010, 21:12:03 »
Bizarre!
Our man here should check for movement in the bushes, link bars and wishbone ball-joint.  If nothing looks out of place,  give all joints a liberal dose of silicon grease spray.
viking6152
« Reply #8 on: 09 June 2010, 21:15:07 »
The only other thing i can think of is the strut that keeps the shock asorber in place!? :-/
pscocoa
« Reply #9 on: 09 June 2010, 21:19:11 »
it does seem to be in that area - will have to get on to it tomorrow
viking6152
« Reply #10 on: 09 June 2010, 21:21:30 »
good luck 8-) :y
« Reply #11 on: 09 June 2010, 22:15:25 »
pscocoa
« Reply #12 on: 10 June 2010, 18:31:19 »
front roll bar drop link is culprit
« Reply #13 on: 10 June 2010, 18:46:55 »
Normally knocks as oppose to creak :-?. Surprising
pscocoa
« Reply #14 on: 12 June 2010, 17:26:09 »
you were right - changed drop links and noise has started again - but everything seems ok. Links were a bit worn and it seems tighter at front but that could be my imagination.
Will keep looking
