Author Topic: fuel consumption  (Read 7973 times)
omega3.0mv6
  • sotton
Re: fuel consumption
« Reply #30 on: 16 June 2010, 23:08:03 »
i dont mean to sound thik i got air con but i dont know how to turn it on there is an eco button what does that do a light comes on when pressed but nothing happens
thanks
« Reply #31 on: 16 June 2010, 23:14:16 »
thanks
Assuming all is as it should be, it knocks the a/c compressor off, which in effect reverts your car to a car without air conditioning. It would still heat if required,but obviously not cool to below outside air temp.  :y
you could read the manual  ::)  ::)  ::)
When you press 'AUTO', you've turned your air con on (does it still have enough gas in there? ;))
« Last Edit: 16 June 2010, 23:15:26 by Andy_B »
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
« Reply #32 on: 16 June 2010, 23:16:13 »
Does nowt when I press mine either. :(
Must get TG to ask his boss how much for a regas.
« Last Edit: 16 June 2010, 23:17:30 by CaptainZok »
TuBy's new whipping boy.
omega3.0mv6
  • sotton
« Reply #33 on: 16 June 2010, 23:29:33 »
i was told ages ago when u switch on aircon the rev counter drops a tad putting more strain on the engine is that correct
thanks
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
« Reply #34 on: 16 June 2010, 23:31:16 »
thanks
No the ECU should speed up tick over to compensate for the compressor load.
omega3.0mv6
  • sotton
« Reply #35 on: 16 June 2010, 23:39:44 »
oh right ok i just read in the manual regards to the eco it says when the aircon is in auto mode u press the eco to save on fuel ?
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
« Reply #36 on: 16 June 2010, 23:53:21 »
When you press eco it switches off the compressor, which takes a load off the engine and saves fuel, but you don't have aircon.
sjc
  • Alloa, Scotland
    • Ultra-dull Audi TDi
« Reply #37 on: 17 June 2010, 06:44:43 »
Oh, and BTW, 1998 E39 540i = 4.4L V8 (285bhp/324lbft) so it's maybe not surprising it drank fuel.
think to get one of them :) 6 speed manual 8-)
Hhmmm... lovely!  Mind you, you can get an M5 from the same series for not much more these days!
sjc
  • Alloa, Scotland
« Reply #38 on: 17 June 2010, 06:49:54 »
thanks
Yep, and if it's auto you have to hold it back more on the brakes at junctions cos the extra revs make it want to "creep" quite a bit more.  If find that a pain in the neck when trying to manouver into thight spaces.
« Last Edit: 17 June 2010, 06:50:34 by sjc »
Kaycee
  • Doncaster
« Reply #39 on: 17 June 2010, 07:37:24 »
well to add my twopennorth i get 32 on my hemel run from doncaster and back once a month and knocking about doncaster 25 im well pleased with mine better than the 2.5 i had and thats with the oil leak at the front i have to put up with but seriously its the best car ive had for fuel consuption and its a 3.2 but if we buy these cars we have to accept that the lovely and serene drive and the rush of power when needed as to be paid for
There is a tide in the affairs of man if taken at the flood will lead on to greater things
duggs
  • Felixstowe
    • BMW 3.0 Sport
« Reply #40 on: 17 June 2010, 13:10:51 »
AND a price well worth paying as far as I'm concerned.
Mind you, at 40p per mile business use, fuel wise, it doesn't really cost me a penny. :y :y :y
Sixstring
  • Lydney, Gloucestershire
« Reply #41 on: 17 June 2010, 14:01:45 »
Lucky you!!! I only get 20p per mile, just breaks even if I'm a bit light on the throttle, or on mototrways a lot. :-[
sjc
  • Alloa, Scotland
« Reply #42 on: 17 June 2010, 14:15:18 »
That's pants, tell them you want more or the company will need to provide transport.  You're allowed up to 40p/mile before you can be taxed, or 45p/mile if you have one or more passengers.
40p doesn't really cover the true running costs of even the most frugal of cars - not when you add up insurance, tax, mot, tyres, servicing & repairs and fuel.
Mikes1670
  • Hull
« Reply #43 on: 18 June 2010, 17:07:53 »
Just turned 28,000 miles (with full history). Has anyone else every done the calculation to check the accuracy of the on board computer. Method to clarify calc. Fill tank to full - reset odometer & onboard computer - run to almost empty - refill tank to full - record litres to refill - record odometer mileage - divide litres by 4.5 to convert to gallons - divide mileage covered by gallons to get mpg then compare with on board computer.
Road Hog Mad
  • Cheshire
« Reply #44 on: 18 June 2010, 17:29:24 »
hmm... 16MPG stop start town work, i.e. Manchester, changes gear before 2,000 revs in an 3.0 MV6 Auto.
16MPG = Shite!
I am tempted to try that injector cleaner stuff but I doubt it works lol
Pages: 1 2 [3] 4  All   Go Up
