Author Topic: wipers  (Read 1144 times)
andy1965
  • cheadle staffordshire
wipers
« on: 18 June 2010, 14:39:15 »
hi all just drove through some heavy showers now when i switch off wipers they stay in the vetical position blocking my vision. any ideas please >:(
amba
  • Medway towns
    • German V6
Re: wipers
« Reply #1 on: 18 June 2010, 17:00:25 »
Linkage has either come adfrift under scuttle panel or both wiper arms are loose on the spindles.
Remove wiper arms and see if the spindles are moving .
Re: wipers
« Reply #2 on: 18 June 2010, 19:06:51 »
That will be the nut loose on the wiper motor, scuttle off,loosen nut further, lift the kinked arm off a little, reposition wipers with kinked arm between arrows on casting, tighten nut, re fit scuttle.
andy1965
Re: wipers
« Reply #3 on: 18 June 2010, 19:43:43 »
thanks will try that. wipers are working fine but stop in wrong position.
andy1965
Re: wipers
« Reply #4 on: 18 June 2010, 23:47:41 »
thank you just as you said nut was loose. :y
Re: wipers
« Reply #5 on: 19 June 2010, 00:53:04 »
We both have the t shirt :y
