Author Topic: Timbuks crank sensor  (Read 7784 times)
theolodian
  • I need a new avatar.
Re: Timbuks crank sensor
« Reply #15 on: 02 October 2006, 18:59:05 »
OK, Kev's sweated enough on this one, I can reveal some additional information which Kev didn't know about...
What they never made clear was that it was turning over too slowly for it to start, whether using battery, another battery, or jumpstarting. Thats how they found it was aux belt slipping on a/c pulley.
So, Kev, you weren't given the full info to be able to correctly diagnose....
Umm, I beg to differ!  See first post.
http://www.omegaowners.com/forum/YaBB.pl?num=1159359830/0#0
 :o ;D ;D
« Reply #16 on: 02 October 2006, 19:02:15 »
Ahh, but you'd implied it was cranking slowly due to 'low battery' ;)
theolodian
« Reply #17 on: 02 October 2006, 19:05:04 »
That was before we tried my battery and then quickly started homing in on the cause.  Nonetheless, I said that it was almost catching.  I don't think it would do that with a bad crank sensor! :D
Timbuk
  • Telford
  • owned a Datsun 120y once!
« Reply #18 on: 02 October 2006, 19:05:17 »
NO no no no no no, hold your horses a minute, hes not getting off with it that easy. Original thread clearly states the car was turning over and trying to fire, it was only the next day after towing car and turning over some more that the a/c pully seized completely.  ;)
 See here for details
http://www.omegaowners.com/forum/YaBB.pl?num=1159303052
Edit:- Must type faster ;D
« Last Edit: 02 October 2006, 19:06:55 by Timbuk »
Timbuk
  • Telford
« Reply #19 on: 02 October 2006, 19:07:44 »
 [smiley=thumbsup.gif]
Kev
  • Glasgow
  • .:The OmegaProject:.
« Reply #20 on: 02 October 2006, 20:38:02 »
And that'll do for me.  Thanks Jamie. ;D
Now as Columbo says, "Just one more thing...", Looking at the post i made after your duff description....
If the fuel pump isn't running while it's turning over then it's the crankshaft sensor.  ;) I'd bet my left bollock on it.  ::)
Also, It wouldn't cough no matter what you sprayed in there, cos if it doesn't know what angle the crank is at, it won't generate a spark either.
* EDIT * You'll also need a working EML to paperclip it.  ;)
Why wasn't that fuel pump running? Does a seized compressor stop the fuel pump from running? Does a seized compressor inhibit spark generation? New one on me if that's the case.  ::)
Was the pump maybe ok, and was running, but you gave false information? Yep, probably.  ;)
I still reckon the V6 lump would still fire, even with a seized compressor, it'd just burn up an Aux belt. MarksDTM concurred with me on this point also.
So i can sleep easy, knowing that i made the correct diagnosis for the information that was presented before me, which was, at best, patchy.  ::)
OmegaProject.co.uk .:.  Fuelled with passion...
[img name=signat_img_resize]http://i94.photobucket.com/albums/l92/xthreezero/omegaproject/oof-sig.jpg[/IMG]
Timbuk
  • Telford
« Reply #21 on: 02 October 2006, 20:48:01 »
[size=72]
                                   MY
                          CRANK SENSOR
                               IS FINE![/size]
Kev
  • Glasgow
« Reply #22 on: 02 October 2006, 20:57:06 »
[size=72]
                                   MY
                          CRANK SENSOR
                               IS FINE![/size]
Please see my previous post. I've said all i need to say. ;)
Timbuk
  • Telford
« Reply #23 on: 02 October 2006, 21:06:09 »
Shall we put this to bed once and for all Kev
My car's running, you've still got all your dangly bits and we've all had a laugh!!!!!!!!!!! Everyones a winner ;)
Taxi_Driver
« Reply #24 on: 02 October 2006, 21:09:06 »
If it wasnt the crank sensor.......what was wrong??? sorry trying to catch up on this thread and may have missed the actual fault  :-[
« Reply #25 on: 02 October 2006, 21:11:06 »
Seized a/c compressor, meaning it wouldn't turn over fast enough...
Timbuk
  • Telford
« Reply #26 on: 02 October 2006, 21:12:42 »
Give me 5 mins and i will write the official story :)
Timbuk
  • Telford
« Reply #27 on: 02 October 2006, 21:16:26 »
 Yep, to cut a long story short, thats it in a nutshell ;)
Taxi_Driver
« Reply #28 on: 02 October 2006, 21:23:41 »
Ahh rite.....thanks.... :)
Kev
  • Glasgow
« Reply #29 on: 02 October 2006, 21:23:53 »
I have. It's done.  ;)
