Author Topic: 3.0l v6 idle speed  (Read 4744 times)
Re: 3.0l v6 idle speed
« Reply #15 on: 25 June 2010, 17:22:38 »
Yes, and EGR valve that's sticking or not sealing will give you a lumpy idle.
mrjimbo
  • Oxfordshire
« Reply #16 on: 26 June 2010, 11:16:29 »
Is it much of a job to alter the idle speed with Tech 2 ?
« Reply #17 on: 26 June 2010, 11:34:26 »
Idle should only be controlled via ICV, by no other means. You can use tech2 to alter the EGR but this will artificiality increase revs. Tech2 should not be used to alter idle...
« Reply #18 on: 26 June 2010, 11:38:40 »
Easy, assuming the actual idle is matching the desired idle
« Reply #19 on: 26 June 2010, 11:40:34 »
I think you may be partially confused there, student.
Idle can be adjusted via Tech2. EGR cannot be adjusted, except for interactive diagnostics. Its OK to adjust idle to get it to where it should be (450 with a/c off on a v6).
« Reply #20 on: 26 June 2010, 12:25:30 »
Thought EGR could be set a certain level, or was that just diagnostics changing rpm  :-/
mrjimbo
  • Oxfordshire
« Reply #21 on: 26 June 2010, 15:10:42 »
Could you have a lookie see for me some time please   :)
I think it maybe related to it being ex-plod, they spent a lot of time at idle with a lot of equipment running so the idle has possibly been raised a bit to help with charging as at 500rpm the input from the altenator would be on the low side compared to what is being required  :y
« Reply #22 on: 26 June 2010, 21:31:11 »
Sure :)
« Reply #23 on: 26 June 2010, 21:31:39 »
It is not adjustable - its set in the maps.
mrjimbo
  • Oxfordshire
« Reply #24 on: 27 June 2010, 01:54:36 »
OK, whens the best time for you ?
« Reply #25 on: 27 June 2010, 08:54:34 »
Err, not this week ::)
mrjimbo
  • Oxfordshire
« Reply #26 on: 27 June 2010, 11:30:37 »
OK, let me know when then   :y
Jabbadad
« Reply #27 on: 30 June 2010, 20:40:19 »
To The Boy, I am a new member "Jabbadad" and have been directed to you ref: My Omega Auto gearbox being adjusted to change into Top at around 45mph to 48mph. It currently goes into Top Gear at 52mph, which is too high for the roads I travel. Can you please help. Jabbadad brian.hunt7@btopenworld.com
01905 22433
Page created in 0.028 seconds with 20 queries.
