Pages: 1 [2] 3  All   Go Down
Author Topic: Auto box again  (Read 4056 times)
unlucky alf
  • worksop, notts
Re: Auto box again
« Reply #15 on: 25 June 2010, 22:10:21 »
as you aint a million miles away, if you need a solenoid ive got two u/s boxes here, solenoids should be o,k though :y
Thanks alf. Would you be able to help me out with the job?
i should think so, its just the small matter of what solenoid does what cos there are a few in there, perhaps someone could give me the wire colours on what solenoids :y
Re: Auto box again
« Reply #16 on: 25 June 2010, 22:12:57 »
Look at the link in my post Alf :y
unlucky alf
  • worksop, notts
Re: Auto box again
« Reply #17 on: 25 June 2010, 22:17:48 »
gotcha!, didnt know they were called something other than an AR35 :-/
Re: Auto box again
« Reply #18 on: 25 June 2010, 22:20:34 »
I thought you knew them back to front, inside out, outside in and all other permutations. You`ve played with `em enough times ;D ;D ;D ;D ;D
unlucky alf
  • worksop, notts
Re: Auto box again
« Reply #19 on: 25 June 2010, 22:24:05 »
oh yes i know how to change complete boxes unfortunately, never delved past the oil pump though, but the solenoids aint to bad to get out, they are just held in by roll pins if i recall correctly.
Tonkapaj p,m me if you need help & arrange a day. :y
« Last Edit: 25 June 2010, 22:26:00 by froggy »
Tonka.
  • Lincoln, Lincolnshire
    • 2000 2.5 CDX
Re: Auto box again
« Reply #20 on: 25 June 2010, 22:27:54 »
well i had 3 busted ones but some thieving git knicked one while i was on holiday, it still had the selector switch on it otherwise i wouldnt have been so peed off >:(
anyhow let me know if you need anything & i`ll strip down one of the others. :y
They will nick anything. Even an AR25.
How will I know what I need alf? Could do with help here TBH  ;)
When did you last change crank sensor?
I have never changes the crank sensor. What is the relevance?
The happiest people don't have the best of everything,
they just make the best of everything they have.
Tonka.
    • 2000 2.5 CDX
Re: Auto box again
« Reply #21 on: 25 June 2010, 22:31:16 »
Phone rang so missed the last few posts.  ::) ::)
Thanks for the offer alf. I will find out what my shifts are on Monday (new job and all that) and let you know what days I am able to cover myself in ATF  ;D ;D :y
Thanks all of you, was ready to have the car crushed this afternoon  :y :y
Tonka.
    • 2000 2.5 CDX
Re: Auto box again
« Reply #22 on: 25 June 2010, 22:32:54 »
Could a faulty crank sensor throw a gearbox fault? Seems a long shot  :-/
unlucky alf
  • worksop, notts
Re: Auto box again
« Reply #23 on: 25 June 2010, 22:54:27 »
well i can bring a whole set of solenoids over, sump gaskets might be an idea unless you fancy using instant gasket, then its down to what tools you have in your toolbox as well as axle stands,not forgetting the dexron3 atf, anyhow let me know when youve got time & hopefully i can make it. :y
Tonka.
    • 2000 2.5 CDX
Re: Auto box again
« Reply #24 on: 25 June 2010, 22:58:42 »
I am okay for tools etc alf. Changed one of these buggers already. The full set of solenoids would be brilliant. I shall source more ATF, a filter and gaskets. Get the thing sorted once and for all  ;D ;D
pscocoa
  • Sandhurst Berkshire
    • Volvo V90 D5 & Grandland
Re: Auto box again
« Reply #25 on: 25 June 2010, 23:36:21 »
That is a personal view on this type of fault when gearbox hangs and then goes limp mode. Just a theory that incorrect engine speed detected by gearbox forces limp mode.
Tonka.
    • 2000 2.5 CDX
Re: Auto box again
« Reply #26 on: 26 June 2010, 14:03:42 »
Just been out into town, in traffic cues and typical urban traffic.
The car behaved perfectly.............
But it did not get as hot as yesterday. I think I may change the ATF tomorrow and see how it goes.
How do I give it a good flushing? ?
Tonka.
    • 2000 2.5 CDX
Re: Auto box again
« Reply #27 on: 29 June 2010, 16:00:53 »
Well, that didn't work........ ::) ::)
Clunking again around second and third.
Lost all drive twice today. First gear fine, second gear fine. Then third gear and the car just revs with no drive.
Into neutral and back into drive and all is well again.
My question is. Can this be cured? Would appriciate all input (alf ;))
sassanach
  • trowbridge
Re: Auto box again
« Reply #28 on: 29 June 2010, 20:21:12 »
i thought you were changing the 2-3 solenoid?
Tonka.
    • 2000 2.5 CDX
Re: Auto box again
« Reply #29 on: 29 June 2010, 20:32:33 »
Yes, I am going to. Just waiting for unluckyalf to reply. I'm sure he will  :y :y
When I dropped the oil on Sunday, it was black. Only been in a year. So I will consider Sundays oil change a flush  ;D ;D
Pages: 1 [2] 3  All   Go Up
Page created in 0.025 seconds with 20 queries.
