Author Topic: Climate control ' Auto ' setting  (Read 3120 times)
Steveplumb
  • Radstock, Near Bath
« on: 15 July 2010, 21:31:45 »
Does any one know what the 'Auto' setting for the vent  blowers is actually selecting automatically or is it really a preset of several vent open and doesn't ever change .
alexandjen
  • Sittingbourne, Kent
  • The Silver Surfer
Re: Climate control ' Auto ' setting
« Reply #1 on: 15 July 2010, 21:38:44 »
The sunlight sensor on the centre of the dash by the screen will alter the airflow to the dash vents :y
« Last Edit: 15 July 2010, 21:39:24 by alexandjen »
Trade club card holder
Code scanner available
« Reply #2 on: 15 July 2010, 21:48:50 »
it turns on the compressor (if outside temp is above a certain amount) it also controls the fan speed automatically, based on what the sun sensor reports. I usually turn the fan speed down manually, but its always left on auto to keep the compressor running. Running Eco during winter is false economy, as come the summer, bang goes compressor!
Shrek
  • Fife , Scotland
« Reply #3 on: 15 July 2010, 23:04:48 »
I thought "AUTO" was only for the air distrubution according to temperature and sunlight sensor etc ... I thought that pressing "ECO" so "ECO" is NOT in the display turns the compressor on depending on outside temp .
I always thought having ECO on the display means the compressor is OFF and therefor its more economical as using a/c uses more petrol  :-/
« Last Edit: 15 July 2010, 23:05:45 by Shrek »
"My Naff Code Reader" and OBD2 readers available .
alexandjen
  • The Silver Surfer
« Reply #4 on: 15 July 2010, 23:11:11 »
Correct - Eco = no air con cooling  :y
Shrek
  • Fife , Scotland
« Reply #5 on: 15 July 2010, 23:13:54 »
I know i put "thought " , but i knew i was right  ;D :y
ECO on dash display = no compressor so no aircon  :y
« Reply #6 on: 15 July 2010, 23:16:01 »
The theory says it's more economical than when in AUTO ie with the a/c ON, but in practice makes not much difference.  ;)
« Reply #7 on: 15 July 2010, 23:19:42 »
Its minimal, if you don't use it the the compressor can easily dry up, and going to cost way more than the amount you save in fuel  :y
Shrek
  • Fife , Scotland
« Reply #8 on: 15 July 2010, 23:34:17 »
I understand that but thats not what the op was asking ... i was stating that eco is supposed to be more economical cause the compressor isnt running so therefore less load on the engine  :y
The Op asked what "AUTO" was for and as far as i am concerened it ditributes the air in the best way to keep the car at the desired temperature set on display .
Having "AUTO" on the display does not turn the A/C on  :y :y
« Last Edit: 15 July 2010, 23:37:57 by Shrek »
« Reply #9 on: 15 July 2010, 23:41:31 »
It does if the outside temp is above a certain amount, i forget what the limit is
Shrek
  • Fife , Scotland
« Reply #10 on: 15 July 2010, 23:45:10 »
The compressor WILL NOT run if outside air is  +5 degrees or lower roughly ... according to the owners manual anyway .
But even if its +30 degrees outside selecting 20 degrees inside and pressing AUTO will not cause the compressor to run unless ECO is NOT on the display  :y
If ECO is showing you will not get cooling because the compressor is turned off  :y
« Last Edit: 15 July 2010, 23:51:52 by Shrek »
Shrek
  • Fife , Scotland
Broomies Mate
  • Bristol, UK
    • Stuff!
« Reply #12 on: 15 July 2010, 23:53:24 »
I assume this is different for countries with a colder climate????  If not, a severe design defect.  I can only imagine that anyone who lives in, say, Canada with a Catera must need a new Air Con COmpressor every couple of years!  :-/
« Reply #13 on: 15 July 2010, 23:56:40 »
i don't think in the 5 years of ownership i've pressed the Eco button!
Broomies Mate
  • Bristol, UK
    • Stuff!
« Reply #14 on: 15 July 2010, 23:58:20 »
I do, but without real reason.  Sometimes, when the fuel light is flashing and you dont have a penny in your pocket, it's a desperate attempt of getting an extra mile from the fumes in the tank  ;D ;D ;D
Page created in 0.03 seconds with 20 queries.
