Pages: 1 [2] 3  All   Go Down
Author Topic: coil pack relocation  (Read 4682 times)
Re: coil pack relocation
« Reply #15 on: 25 July 2010, 11:04:27 »
Is it possable to relocate a coil pack to a better position, whilst still having all the ht leads reach. (and then leaving the old broken pack in its position.
Thanks
David
For those who can't read, this is the actual question asked. :y
Wondered what the scroll wheel on my mouse was for  ::)
We've answered his question! - Its current location is the best place for it, its at the back out of the way, its not a service item, its in relative cool air that gets tunnelled out of the engine. There are no other suitable locations in V6.
Sure you can get that stuck bolt out, a mirror against bulkhead should let you see how it needs attacking.
When refitting you can get away with two bolts on the replacement one  :y
pedroMV6
  • York
  • Der Metzgermeister
« Reply #16 on: 25 July 2010, 14:46:32 »
Thanks
David
Wrong!
The question was can it be relocated, and the answer is definitely yes.
I think GM should have kept it in the same position as the FWD V6 cars.
« Last Edit: 25 July 2010, 14:47:37 by PedroMV6 »
« Reply #17 on: 25 July 2010, 14:53:14 »
Thanks
David
Wrong!
Vectra V6 setup is fundamentally flawed, its location in the Omega bay, is the best location, and should not be moved. I've seen photos of it being moved to behind the oil filter, but thats not viable, its not secure, its in the heat of the engine bay, even more prone to water ingress from scuttle. Can it be relocated, yes. Should it, no.
Whats the amazing place you would mount it?
« Last Edit: 25 July 2010, 14:55:46 by tunnie »
pedroMV6
  • York
« Reply #18 on: 25 July 2010, 15:40:09 »
No need to try and be clever.
I would simply use the mounting arrangement as the FWD V6 cars - I thought you might have gathered that from previous posts.
Your opinion is not always right Tunnie, some of us have actually worked on cars - for me, in motorsport at high levels and at home in my own garage, therefore have a fair nbit of experience.
I fancy your experience is taken from the pages of this forum and others freely available on the internet.
It's pretty obvious to me that as a young lad, you like to think that you know the lot - trust me, you don't.
I shall not bother to reply to your posts again as it's clear to me that you like to wind people up in that condescending way of yours.
« Reply #19 on: 25 July 2010, 15:48:30 »
Hi Pedro.
I am not aware that the front wheel drive cars are different, where is it mounted on them?
« Reply #20 on: 25 July 2010, 15:54:38 »
Not at-all, i am just pointing out that the current location is the best. No need for moral high ground of working in motorsport at 'high' levels, assume that makes you more knowledgeable than someone who works in  banger racing or maybe a mechanic or even more knowledgeable than the DIY'er?  :-/
I don't mind being corrected, so please tell me in your opinion, the superior location for a DIS pack?
« Reply #21 on: 25 July 2010, 15:55:34 »
quick google on the 2.5 V6 Vectra, leads look to go to the same place as Omega  :-/
Bent valve
« Reply #22 on: 25 July 2010, 15:58:42 »
Well said!  :)
Bent valve
« Reply #23 on: 25 July 2010, 15:59:53 »
Behind the scuttle?
« Reply #24 on: 25 July 2010, 16:01:39 »
Behind the scuttle?
Err thats the Vac box for multi rams, you can see the 2 front vac pipes going in, like at the bottom of the V6 trumpets.
Of course that is my opinion  and my opinion may not always be right.
« Last Edit: 25 July 2010, 16:02:26 by tunnie »
Bent valve
« Reply #25 on: 25 July 2010, 16:12:32 »
Behind the scuttle?
You  misunderstand what I said. (Behind the scuttle?)
refers to the fact that the vectra leads do not go to the same place as the Omegas
« Reply #26 on: 25 July 2010, 16:18:09 »
Behind the scuttle?
Apologies for mis-understanding  :y
Vectra it's same place, as Omega i believe its bolted to the back of the block, its just in FWD thats in the middle of the bay on the right, when the engine is rotated it sits back behind the scuttle.
Bent valve
« Reply #27 on: 25 July 2010, 16:35:59 »
[/highlight]
 As he is not replying to your posts any more, might I suggest that the superior postion is anywhere that one would like to put it in the engine bay that one is happy with.  It dosent have to be bolted to the rear of the cylinder head just because GM put it there. In fact you could argue that the dispack actually gets hotter as a result of it being in contact -albeit indirectly- with the head than mounting it as you put it  'in the heat of the engine bay'
Bent valve
« Reply #28 on: 25 July 2010, 16:39:02 »
Behind the scuttle?
Apololgy accepted :y
« Reply #29 on: 25 July 2010, 16:45:04 »
[/highlight]
Totality agree, I've modified a few of GM's choices, but the the problem with DIS is where else to put it? V6 bay is tight as it is. Its a real struggle to mount just 6 LPG injectors, and they are tiny! Only space big enough is behind the oil filler, its more open to elements there, and more engine heat, and possible fluids from scuttle foam.
Also its only once in cars life it needs to be replaced, it maybe slight pain to get access but its only a once in a cars life job, its not like cam covers or oil changes.
If one bolt is being a git, magic socket it out, or, get sammy on it, just 2 bolts would be enough to hold its replacement.
OP asked if it can be moved, you can if you want to. But my opinion is that it should stay, think most would agree  :y
Pages: 1 [2] 3  All   Go Up
