Author Topic: Camcover gaskets prices!!!  (Read 5925 times)
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
Re: Camcover gaskets prices!!!
« Reply #30 on: 23 July 2010, 22:54:23 »
Doing them now won't hurt, may not help your leak but needs doing anyway.
« Last Edit: 23 July 2010, 22:54:37 by CaptainZok »
TuBy's new whipping boy.
« Reply #31 on: 23 July 2010, 22:57:19 »
Doing them now won't hurt,  ....
Too dark now to see what you're doing!  ::)  ::)  ::)  :y
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
« Reply #32 on: 23 July 2010, 22:58:44 »
He may have a nicely lit garage. ;D
« Reply #33 on: 23 July 2010, 22:59:53 »
I do, but I can't get my car in it  :-?  :y  :y  :y
« Reply #34 on: 23 July 2010, 23:03:56 »
As I understand it ... but probably wrong ... the gasket "forms" (flattens?) itself to the face of the head when first fitted and so makes a good seal.
If the pressure then builds up due to poor breathing, the gasket "pops" - like a safety valve - somewhere along its length.
From that point on it will NOT "reseal" and will leak, either by pressure if the breathers are not cleaned.. or by capilliary action if they are.
Once they leak .. they continue to leak ...
« Last Edit: 23 July 2010, 23:04:35 by entwood »
« Reply #35 on: 23 July 2010, 23:10:51 »
I would say the original gaskets have probably hardened with time and that cleaning the breather wouldn't have much of an effect.
« Reply #36 on: 24 July 2010, 02:08:36 »
Not a huge difference between what you got and Andy's TBH ..
Andy's  .. £31.15 inc VAT
Yours ....  £26 + VAT = £30.55
I know "every little helps" .. but .60p in £30 is not a lot !!  :)
Better in my pocket than Vx, and a lot cheaper than retail  :y
Not really questioning Andy's prices, more pointing out difference compared to retail - and only posting on this topic as got a very recent receipt to hand for these items.
« Reply #37 on: 24 July 2010, 09:47:01 »
Cleaning breathers is unlikely to cure current leak, but you really, really, really do need to clean them when you replace the gaskets, before starting the engine.
  • Auckland
    • Mazda MPV
« Reply #38 on: 24 July 2010, 14:52:54 »
My theory is that a new seal is elastic enough to seal perfectly but over time it both hardens and sticks to the metal surface. If there is enough pressure to unstick it and start the leak then capillary attraction draws oil into the joint and it behaves like a wick thereafter.
« Reply #39 on: 24 July 2010, 15:14:54 »
Yes Andy and Entwood, I think you are both right.  Certainly whenever I have removed the old gaskets from the cam covers they are hard, brittle, and very rarely stay in one piece ::) ::) ;) ;)
GaryBC
  • Egham, Surrey
« Reply #40 on: 26 July 2010, 09:26:56 »
Despite being slapped down i have done my MV6 and both my 2.5cdx cars  from a supplier off ebay and after 40,000 after the change (2.5 v6) still no leaks. My electric fans on the MV6 have now stopped but thats a different matter. LOL
Who?
GaryBC
  • Egham, Surrey
« Reply #41 on: 26 July 2010, 09:40:14 »
They will defo get cleaned when I do the gaskets! I was just wondering if there was worth cleaning them while I am sourcing gaskets at the right price. Looking at the How To guide here would suggest that it is a pretty straightforward job in it's own right.
« Reply #42 on: 26 July 2010, 09:45:27 »
Certainly on mine .. with all the "stuff" you have to take off to get to just one side .. LPG, inlet manifold etc etc ... I would only consider doing both whilst in there .. the additional time/cost is peanuts compared with having to do the "other" side a few months later...
Found that the hard way when the first time I did them the passenger side one leaked on reassembly .... pain in the neck to take it all apart just to reseat the half-moon .. :(
Just my views .. nowt else . :)
TECHNOPUG
  • Islington - London & Essex
« Reply #43 on: 27 July 2010, 12:36:52 »
Make sure that the dealers give you 4 FOUR cam cover gaskets, not a pair, as in two cam cover gaskets in 1 pack......ask me how I know, go on, ask.......  >:(
« Last Edit: 27 July 2010, 12:40:14 by TEKNOPUG »
GaryBC
  • Egham, Surrey
« Reply #44 on: 27 July 2010, 23:29:36 »
Ok. "How do you know this?" (Well, someone had to!!) ;D
Pages: 1 2 [3] 4  All   Go Up
