Author Topic: cambelt change!  (Read 3141 times)
GaryBC
  • Egham, Surrey
Re: cambelt change!
« Reply #15 on: 05 August 2010, 13:47:52 »
You can change the belt etc without a locking kit, provided the cams are aligned before you take off the old belt. If you are careful, it boils down to taking off the old belt, replacing the pulleys and tensioners and putting the new belt on. Provided it is still aligned then there should not be a problem.
Ken
That sound feasible if the cams didn't move on the valve springs. But they will. The plastic cam lock will hold both cams still relative to each.  :y
Surly you can cut the old belt in half, longways while still fitted, then push on the new belt and simply cut off the old one, everything should have stayed in place... :D :y
This sounds like one of those ideas which, because it is so blindingly simple, nobody has ever thought of before! (So long as it is only the belt being changed - and none of the rollers etc.)
Re: cambelt change!
« Reply #16 on: 05 August 2010, 15:42:42 »
Ken
And that's where the Devil is in the detail! It is rarely that the belt needs changing purely for itself, but far more likely the belt tensioner bearings are worn or the roller bearings are noisy, & it's recommended that the waterpump is changed as well as the roller & tensioner when the belt life (40K or 4 years) is reached, and Vamps idea would not be workable in that scenario unfortunately  :(.
IMO, I also think you would have a B* of a job getting a new belt to stretch enough to fit without getting some slack from the belt tensioner? :-/ ;)
stevo61r
  • West Midlands
Re: cambelt change!
« Reply #17 on: 05 August 2010, 23:05:27 »
My car has now just done over 80000 miles so is due (probably overdue!) it's cambelt change. I have a mate that should be able to do the job for me.
For the cambelt kit and the water pump on ebay it's approx. £130 with delivery.Anybody know a cheap supplier as my local parts supplier can't beat this price?
Seems expensive - try these people http://www.buypartsby.co.uk/timing-belts-and-kits-final.php?year=2000&Submit=Next&make=Vauxhall&model=Omega&sub=&eng=2.2000 - kit £56 +deliv.  Usually Contitech/skf parts (OEM supplier). :y
Thanks for the link.
I have purchased the kit and the water pump, with delivery cost approx £95. Not bad at all  :)
My friend has all the kit to do the job and is charging me next to nothing.
GaryBC
  • Egham, Surrey
Re: cambelt change!
« Reply #18 on: 06 August 2010, 10:56:51 »
Can he be my friend too please?! ;D
And is the c£95 for OEM parts? That sounds like the best deal ever!!
Re: cambelt change!
« Reply #19 on: 06 August 2010, 13:48:05 »
Indeed. Certainly the hard way to do it, and it will still fail because 90% of failures are the tensioners and nothing to do with the belt.
stevo61r
  • West Midlands
Re: cambelt change!
« Reply #20 on: 06 August 2010, 19:36:30 »
Re. GaryBC.
All parts are OEM they arrived today, very suprised as I ordered them at 15:00 ish yesterday.
Great service :y
My friend who is fitting them owes me a few favours as I've helped him out in the past  ;)
