Caravanning - Omega's as towcar!
Started by SMS01, 19 July 2006, 00:39:51
v6man54deg              Geffd
I also own a caravan although I don't own an Omega i have a V6 vectra - which tow's great, on makes and models - I have an Lunar - they are known for lightwieght vans - mine is around 17.5ft 5 berth but is only 1240 kg's well within the 85%.
I have towed vans for a good few years on and off - it can be quite a challenge at first but as long as your car is in good order you shouldn't have much of a problem. I would advise you join the caravan club - you can get a lot of advice from them plus they do caravan towing courses .
I have had old ones - the trouble is they look ok until you get on a site and you look like the Gypo lol, no they are usually have something wrong with them!!! just like old cars.
i bought a new one last year from a show - got a huge discount there too - I would recomend it, but don't buy a small one, they look huge until you go away in them.
Best to borrow / higher one before you commit to buy!!!!!
as for stabilisers - i use an alco one - it replaces the hitch on the caravan and uses brake pads on the tow hitch - by far the best type to use.
And as for cheap holiday - its not these days, your car will feel like a vauxhall Viva when towing but will drink juice like a V12 jag.
QuoteFollowing on from the Caravan Tyre warning earlier, I am thinking of getting a caravan at some stage - not a new one by any means, but fancy something to tame the 3.0 on the road..
Any recommendations for an ideal sort of size of van/weight etc for the Omega? Ideally I would prefer a larger van 3/4/5 berth just for space and comfort, but would appreciate any pointers or advice from our existing caravanning members to look out for should I finally decide to take the plunge.
Mine is a 3.0 elite estate on a P - so not new but has typical features of the specification, obvious thing I would only drive it with an anti-snake device as have seen too many vans on their side for various reasons.
Any other mods necessary for the meega or other things I should be aware of with the meega towing?
Cheers for any advice
Steve
V6 problems solved : Worked at the V6 Engine plant for 13 years on durability testing and warranty issues, this job included many trips to Russelsheim, Trollhattan, Michigan, Atlanta,keiserslaughtern.
Omegatoy
Ok all you caravan Gurus?? anyone any idea of the nose weight of a Hobby 25ft? looking at one and not sure whether to go for it or not???
will be towed by a TD (chipped whoosh!!!!) estate with airshocks
Omegatoy
Martin_1962
QuoteOk all you caravan Gurus?? anyone any idea of the nose weight of a Hobby 25ft? looking at one and not sure whether to go for it or not???
Omegatoy
Wrong idea - you LOAD it to 75kg (ie use the contents as ballast) this is hte beest way.
Also why not use the other Omega as a tow car!!
Omegatoy
Omegatoy
Sorry mate by Nose weight i meant the all up weight to see if its within limits!!
Omegatoy
Martin_1962
Is it twin or single axle - any single axle will be fine
archermk
I collected and towed my caravan yesterday behind the Omega for the first time. I almost forgot the caravan was there (except for the double hop over speed humps).
The most interesting part of the day was fitting & wiring up the towbar. I had it booked in at a place in Nuneaton earlier in the week to be fitted but they took one look at the LPG tank in the boot and declined. So DIY it was. I had to drill up into the cross member near the axle rather than down from inside the bonnet because of the tank. I placed a paving slab under the tank to stop the drill going too far up.
The towbar fitting took about 3 hours, taking it easy. But the electrics were a bit trickier. Incidentally does anyone know where I can get a color-code table for the wires in the loom at the rear of the boot. I've just got a couple to re-do.
Omegatoy
QuoteIs it twin or single axle - any single axle will be fine
Twin axle mate gonna tour Spain for 6 months to see if we like it, so need the room!!!
Omegatoy
Martin_1962
Find the weight and we will let you know
egcc
#23
HI steve,
We tow a 2005 Swift Challenger 55OL single axle fixed bed  4 berth Model -
caravan weight unloaded = 1214kg.
caravan max weight loaded = 1432kg
I believe the van we have is probably one of the heaviest single axles around, the omega 2.6 pulls it like a dream, we tend to travel light and it is important you load the van evenly.
Ideally the weight ratio between the car and caravan according to the caravan club should be 85% but some  experienced caravanners do tow at 100% not recommended.
Obviously it's better if the cars kerbweight is higher than the caravan when the caravan is fully loaded.
How to work out the towing ratio =
Loaded caravan weight divided by car kerbweight x 100% = hopefully 85-90% or lower.
Mine works out - 1432kg divided by 1630kg x 100% = 87% if i load to the max and the unit is very stable.
useful links vehicle kerb weights http://www.cuddles.abelgratis.net/kerbweights.htm
A very good caravan forum  http://www.caravantalk.org.uk/index.php?act=idx
Another good tip is to weigh the car on a weigh bridge and even better the caravan if you can before you buy.
hope this helps.
regards dave.
Vauxhall Omega  2.6 CDXI Auto 2003 Saloon https://en-gb.facebook.com/TheDeadXiii
