Author Topic: IT'S ALIVE!!!!!!!!!!!!!!!!!  (Read 6247 times)
mijfife
  • Rosyth, Fife. Scotland
  • AAARRRRGGGGGGGGG, IT'S WAS ONLY A GLS!!!!!!!
« on: 03 October 2006, 17:33:30 »
Yep, I can finally report that my previously enginless GLS Estate is now moving under it's own power once more after a successfull heart transplant  :) I collected the engine on Friday and spent Friday afternoon changing the bits that the breakers broke taking it out along with the inlet manifold which is set up with the LPG stuff. Saturday afternoon was spent drilling out the broken exhaust manifold stud and finally lowering the engine into the car. Sunday and Monday was spent working out where everything connected to and taking bits of to gain access to other bits that needed to go on first  >:( Today I managed to get it to cough into life.  8-)
Bearing in mind that I never took the engine out, the only thing I'm not sure I've got right is a couple of the thick vacuum pipes at the back that come from the unit next to the DIS. Would it make much difference if they are mixed up? I've still got the alternator top adjuster thingy to get as that's still missing. Engine management light is on but I'm not sure if thats from the previous distruction of the old engine or would it have reset itself with the battery being disconnected for several months?
   mot is booked for next Wednesday so that'll give me time to change the cambelt, oil etc and sort out a couple of other little bits & pieces.  So far so good............
Cheers Jim
The fleet consists of a Singer Chamois Coupe, an Imp based kit car - BS Nymph, and a Kawasaki GPZ 900R (& a Toyota RAV4 LPG for the work horse!)
Markie
  • Lanarkshire, Scotland
    • RS4, BMW X5, Range Rover
Re: IT'S ALIVE!!!!!!!!!!!!!!!!!
« Reply #1 on: 03 October 2006, 17:59:42 »
from memory - vacume pipes may make a big difference if there abck to front....
eml wont fail an mot, was going to suggest paperclip test but its post facelift isnt it?
well done a major feat in itself!!
mijfife
« Reply #2 on: 03 October 2006, 18:05:35 »
Thanks Markiec, I was well chuffed that I managed to get it running at all! I'm sure there's an Omega in the breakers with everything intact so I'll try and have a look tomorrow. The car is running okay but there is an uneveness at idle so could be something amiss.
Cheers Jim
« Reply #3 on: 03 October 2006, 18:38:43 »
Well done m8  ;)
Timbuk
  • Telford
  • owned a Datsun 120y once!
« Reply #4 on: 03 October 2006, 18:43:03 »
Well done sir, another meega brought back to life ;)
Taxi_Driver
« Reply #5 on: 03 October 2006, 19:06:26 »
Well done  :) Something i dont think i would be able to achieve
Markie
« Reply #6 on: 03 October 2006, 19:11:14 »
Sure you would  ;)
Tell you something the satisfaction of turning the key for the first time in a big job and hear it fire into life is an amazing feeling  :)
Timbuk
  • Telford
« Reply #7 on: 03 October 2006, 19:16:38 »
Sure you would  ;)
You're not wrong there, great feeling on saturday after Bo Bo and i changed our cambelts, even though we had expert help to hand, its still great when it fires up ;)
Markie
« Reply #8 on: 03 October 2006, 19:18:36 »
Sure you would  ;)
but on the other side of that dont you hate the split second feeling of dread as your about to turn the key and wonder if all is well  ;D ;D ;D
Timbuk
  • Telford
« Reply #9 on: 03 October 2006, 19:25:15 »
Sure you would  ;)
 Well yeah, you're right there too, Im sure TB and Theo won't mind me saying, even though you know its right and everything has been checked and double checked, you still have that  ' will she, won't she feeling ' ;)
Bo Bo
  • Coventry
« Reply #10 on: 03 October 2006, 19:52:45 »
Sure you would  ;)
Yeah, it was a great feeling, still can't quite believe it!
« Reply #11 on: 03 October 2006, 19:57:45 »
Cambelts are easy enough, and engine transplant would be far more daunting....
Timbuk
  • Telford
« Reply #12 on: 03 October 2006, 20:02:41 »
I totally agree, but its the same with everything, its only easy if you know what you are doing or have the confidence to tackle the job
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
« Reply #13 on: 03 October 2006, 20:33:32 »
The complexity of the V6 motor is daunting but with some expert guidance and support (plentiful on here) one can work up the confidence to do quite major work.
All in all a glowing testimony to the guys on here.
TuBy's new whipping boy.
Timbuk
  • Telford
« Reply #14 on: 03 October 2006, 20:37:59 »
Correct Captain, I am quite happy to tackle anything on the meega now, knowing that a true meega expert or 50 are only a click away if you run into trouble ;)
