Author Topic: SPD/IF  (Read 3410 times)
Re: SPD/IF
« Reply #15 on: 07 January 2008, 20:32:15 »
Ah, OK. It should work. :y
shyboy
  • Southport, merseyside.
    • Mazda 6
Re: SPD/IF
« Reply #16 on: 07 January 2008, 20:35:58 »
Who the hell invented this f---ing language?
Martin_1962
Re: SPD/IF
« Reply #17 on: 07 January 2008, 20:46:30 »
Just do not use TV sound?
Looks like HDMI audio is not the same as SPD/IF
Search on HDMI audio
Some progs, can't be arsed to get up to turn on sub for surround system (being another ill concieved piece of sony junk, it doesn't come on with amp remote), so need to have sound going to TV.
The vga takes spd/if, and sends it up the hdmi...
My SONY STR-DB930 nicely diverts the Bass to my Castle floorstanders
Martin_1962
Re: SPD/IF
« Reply #18 on: 07 January 2008, 20:48:50 »
Gotcha. It's a combined optical/digital output with the optical output in the centre hole of the phono?
I'd try it :y
Its got seperate optical and phono digital outs on a seperate daughterboard, connected to a single spdif on motherboard.  I was thinking of taking it off the back of the phono digital out...
I haven't done anything that mad since I fitted a NICAM decoder to a VCR.
Sounds doable - what have you got to lose? You can always unsolder.
Since it is split off there will somewhere you can easily intercept the data
Martin_1962
Re: SPD/IF
« Reply #19 on: 07 January 2008, 20:49:58 »
Sony Phillips Digital Interconnect Format
TOShiba Link
« Last Edit: 07 January 2008, 20:50:51 by Martin_1962 »
Bandit127
Re: SPD/IF
« Reply #20 on: 07 January 2008, 20:53:39 »
My PC MCE has digital out, both optical and coax.  The VGA card has HDMI, and a SPD/IF in. My surround amp has both coax and optical SPD/IF inputs.
What I need to do is connect SPD/IF to the VGA SPD/IF in (to send audio up HDMI cable, along with video) and simultaneously send SPD/IF to the surround amp.
Can I simply use optical to amp, and solder the wires from vga card to coax connector on motherboard?
What are you trying to do? I would take a guess at sending digital audio to Amp and TV in parallel? But I don't think I'm right.
Sorry, but it's not clear from original post...
Jim
Golfbuddy
  • Cornwall
  • I'm On An Economy Drive
Re: SPD/IF
« Reply #21 on: 07 January 2008, 20:54:00 »
Not sure if I'm pleased or saddened by lack of (proper) responses:
Pleased, as it appears I'm not as stupid as I thought,
Saddened, the fact that it appears I know as much as anyone here about it makes me chief geek :(
I'm not normally worried when I don't know the answer to most of the questions that are asked on here. What does bother me is when I have absolutely no idea what the question means in the first place, let alone the answer.  :-[
[size=24]        [/size][/b]
Re: SPD/IF
« Reply #22 on: 07 January 2008, 21:06:44 »
Jim
Exactly as you say, parallel to TV and amp
Bandit127
Re: SPD/IF
« Reply #23 on: 07 January 2008, 21:51:40 »
Jim
http://www.maplin.co.uk/Free_UK_Delivery/Digital_Optical_Splitter_33712/Digital_Optical_Splitter_33712.htm
Anything else (e.g taking a simple phono out from the amp) will probably wreck synchronisation of the sound signals. You are still at the mercy of the A/D circuits in the amp and TV. ...good luck!
Re: SPD/IF
« Reply #24 on: 07 January 2008, 21:56:54 »
Tap off the coax as said.....there such high impedance that it wont make any odds. Keep the cable short though because it will no longer be matched.
And whilst we are talking of TLAs etc, working in the Telecoms equipment industry we have loads.....and Ericsson use abreviations for all the servers to.....we have one called PRIM, one called GASK etc and today I was looking to see if there was a system that did customer facing change control.......
......well, I found it .......and its called PISS! ;D
Re: SPD/IF
« Reply #25 on: 07 January 2008, 22:10:58 »
Scenario is little complicated ..Dont worry  :y
Re: SPD/IF
« Reply #26 on: 08 January 2008, 11:01:31 »
Jim
Seen the opticals before, but of no use to me (VGA card no optical in)
Re: SPD/IF
« Reply #27 on: 08 January 2008, 11:03:49 »
Thanks.
The cable is one of those silly twisted cables (similar to PC power switch cable or LED cable). Will need to be about 8" long.
I may get scared and pop it over, along with a new sump plug, as my soldering has got shocking lately :(
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
Re: SPD/IF
« Reply #28 on: 08 January 2008, 11:29:22 »
Apart from Martin does anyone know what the hell he is on about.???????????????????????????????????????????? ;D
Jaguar XJ6
Martin_1962
Re: SPD/IF
« Reply #29 on: 08 January 2008, 11:33:12 »
Mark does as well
