Author Topic: Gearbox  (Read 1763 times)
sport
  • Stoke on Trent
Gearbox
« on: 11 August 2010, 22:46:10 »
Hi i can not get any gears when engine cold when engine running but can only get gears when engine is turned off.
I have to start in gear and for the first 10 miles make sure i get in first before i stop otherwise i have to turn engine off to get any gears.
When driven at least 10 miles gears are ok
Have checked clutch level ok
2.2 manual
« Last Edit: 11 August 2010, 22:46:55 by sport »
Re: Gearbox
« Reply #1 on: 11 August 2010, 23:06:50 »
Checked manual box oil level?
Krax
  • Sweden
Re: Gearbox
« Reply #2 on: 12 August 2010, 18:16:46 »
See PM
sport
  • Stoke on Trent
Re: Gearbox
« Reply #3 on: 13 August 2010, 09:56:01 »
Hi Yes its up to the filler level .Do i need the engine running when checking and filling
And if its the clutch would it do it all the time
Re: Gearbox
« Reply #4 on: 13 August 2010, 10:01:12 »
Could well be that the clutch is dragging.
If you pump the clutch a few times does it then engage?
If you sit on level ground in 1st gear, brakes off and clutch fully depressed does it start to "creep" forwards?
Is the clutch smooth when taking up drive or does it judder?
Any sign of leakage of clutch fluid or oil from the bottom of the bellhousing?
If all looks well I would start by bleeding the clutch hydraulic system which must be done with a pressure bleeder "in reverse" by forcing fluid into the slave cylinder bleed nipple.
sport
  • Stoke on Trent
Re: Gearbox
« Reply #5 on: 14 August 2010, 22:11:22 »
If you pump the clutch a few times does it then engage? no
If you sit on level ground in 1st gear, brakes off and clutch fully depressed does it start to "creep" forwards? yes when cold
Is the clutch smooth when taking up drive or does it judder? smooth but it has judderd a few times
Any sign of leakage of clutch fluid or oil from the bottom of the bellhousing? no looks dry
If all looks well I would start by bleeding the clutch hydraulic system which must be done with a pressure bleeder "in reverse" by forcing fluid into the slave cylinder bleed nipple. ok i will try this thanks
Welung666
Re: Gearbox
« Reply #6 on: 15 August 2010, 06:00:19 »
Sport, if you're near enough to me I can have a look for you. Where in the Midlands are you?
sport
  • Stoke on Trent
Re: Gearbox
« Reply #7 on: 16 August 2010, 18:46:02 »
st4 postcode
