Author Topic: help please  (Read 1081 times)
chelski
  • Eastleigh
help please
« on: 16 August 2010, 22:27:15 »
hi
don't know if any one could help problem with idle on 2.5 omega
no fault codes chap came out today , crank sensor replaced idle valve replaced last year throttle switch replaced plugs fine t leads are only year old what it does is on start up the needle use to be dead still just below 500  now it flutters up and down almost stalling seems to be getting worse i serviced it before all this started iv retraced my steps 3 times every thing is in place
any help would be grateful.
Darren
Broomies Mate
  • Bristol, UK
    • Stuff!
Re: help please
« Reply #1 on: 16 August 2010, 22:29:13 »
Have you dislodged the MAF sensor when replacing the Air Filter?
« Last Edit: 16 August 2010, 22:29:26 by Broomies_Mate »
chelski
  • Eastleigh
Re: help please
« Reply #2 on: 16 August 2010, 22:31:59 »
would that come up on computer sorry how do you mean dislodged
Broomies Mate
  • Bristol, UK
    • Stuff!
Re: help please
« Reply #3 on: 16 August 2010, 22:34:24 »
It's only placed into a 'hole' in the main air induction pipe, just beyond the Air Filter housing.  It wont show on the Multi-Function Display, if thats what you mean?
I replaced the Air Filter on mine in a massive hurry, then got rough idle... the MAF had worked slightly loose.  I popped it back in, and all has been well since.
« Last Edit: 16 August 2010, 22:34:48 by Broomies_Mate »
chelski
  • Eastleigh
Re: help please
« Reply #4 on: 16 August 2010, 22:35:25 »
i will go have a look
Re: help please
« Reply #5 on: 16 August 2010, 22:35:38 »
hi
Darren
What did you actually do ?? As it would appear something has changed.
One possibility is you've dislodged a vacuum pipe accidentally, or induced a vac leak unknowingly. With the engine running spray around close to the engine but lightly with carb cleaner, in a methodical pattern. If the engine note suddenly picks up the carb cleaner has been sucked in and burned as fuel .. thats where your vac leak is ...
Fix the leak, wipe the engine with paper towel .. problem solved and a clean engine ..  :)
chelski
  • Eastleigh
Re: help please
« Reply #6 on: 16 August 2010, 22:40:10 »
nope that bit looks fine
chelski
  • Eastleigh
Re: help please
« Reply #7 on: 16 August 2010, 22:53:38 »
hi everyone just disconnected maf sensor and started tick over dead straight plug back in and all over the place
would this be my problem
