Author Topic: Tyre wear  (Read 2882 times)
Re: Tyre wear
« Reply #15 on: 20 August 2010, 16:02:06 »
Put 2 psi more in the front tyres.
Re: Tyre wear
« Reply #16 on: 20 August 2010, 16:11:39 »
I found falkens a little choppy approaching 32/33 :-/
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
Re: Tyre wear
« Reply #17 on: 20 August 2010, 21:17:04 »
So what is the recommended pressures I mostly drive without any passengers, but occasionally tow a caravan with one passenger.
sport
  • Stoke on Trent
Re: Tyre wear
« Reply #18 on: 20 August 2010, 21:30:39 »
 39 (front) 45 (rear) when towing, 30 (front) 32 (rear) solo.
Re: Tyre wear
« Reply #19 on: 20 August 2010, 22:34:36 »
There is a chart in FAQ with the tyre pressures iirc, bit ime what feels right on one set of tyres may not necessarily work with another set, ie falcon 912 seemed better at 30,even though I pumped them up to 35/6 at times to get them to stay straight but sc3 s run better at 33/4.
I really should stop mentioning 912's though... Sh!te tyres.  >:(
Re: Tyre wear
« Reply #20 on: 21 August 2010, 01:49:31 »
i run mine at 41psi for the fronts, and 48psi at the rear. car is 3.2 ex plod estate with self levelling. i use full load pressures as i never know what the load will be from job to job :-/ same idea but different pressures with my vectra saloon. also pressures should be higher with higher speeds :-X if you spend all your time pootling around town by yourself then the basic pressures will be fine, if you spend your life at 80 ish all day long with the car loaded, then the higher pressures will be better... ;)
