Pages: [1] 2 3  All   Go Down
Author Topic: Kenlowe Hotstart: Engine pre-heater  (Read 5353 times)
I_want_an_Omega
« on: 19 August 2010, 10:22:15 »
Does anyone on OOF have one of these mains powered devices fitted to their Mig?
They seem quite popular with Autobhanstormers members, but I don't recall seeing anyone on here mentioning that they have one fitted.
I had one on a V6 many years ago and removed it when I sold the car. I've still got it and am contemplating fitting it again before winter sets in.
Thanks .......... Rob
Abiton
Re: Kenlowe Hotstart: Engine pre-heater
« Reply #1 on: 19 August 2010, 10:41:05 »
Not on the mig, but I put one on my Golf last autumn.
I like it.  Great to drive off knowing that the engine is already warm, and heaters will work straight away.
Probably easier to find space to site it on a 4-pot than a V6, though I've not really eyed it up in either case.
Omegas do warm up a lot quicker than my Golf though, so cost/benefit may not be so clear cut.
I don't do much in the way of short journeys, so I don't save a huge amount of fuel by cutting out the cold-start.  Probably evens it out so that winter and summer economy is about the same (petrol-wise), not counting the electric cost (non-negligible these days  ::)).
Try it.  :)
« Last Edit: 19 August 2010, 10:42:02 by Abiton »
2woody
  • Northumberland
« Reply #2 on: 20 August 2010, 09:51:18 »
one model of Omega 2.2 Dti ? has one as standard.
I would have thought it very useful for LPG - it would mean that you never need to start on petrol
« Reply #3 on: 20 August 2010, 13:30:48 »
Yes, the 2.2Dti was a wesbasto diesel heater as standard....although when not maintained they billow smoke as the fans sieze up!
Cliffo B
  • Leeds West Yorkshire
    • 03 3.2 Elite Estate
« Reply #4 on: 24 August 2010, 00:18:38 »
Had one fitted for about 5 yrs,I think there very good,in fact would never be without one,can be fitted to V6 ok. I fitted mine to my previous 2L Cav then my MV6,and transferred it to my present Elite. Its nice to start a journey and have your motor hot as if its done a 20ml run and there's also the advantage to the engine of no cold starts must mean less wear I posted up about them way back shortly after I joined the Forum. Of course you need to have a garage or as in my case a car port with a mains 13A power point
Broomies Mate
  • Bristol, UK
    • Stuff!
« Reply #5 on: 24 August 2010, 00:30:46 »
Showing my age here (or lack thereof).  How does it work?  :o
hotel21
  • The Kingdom of Fife
« Reply #6 on: 24 August 2010, 00:34:04 »
As I recall, heating element into the water system which causes heated coolant to circulate thermally around the block.  But will be happy to be corrected....
« Reply #7 on: 24 August 2010, 00:34:05 »
part of the car's coolant system is plumbed in via a box with a kettle element in it. You plug the element in & it heats the coolant. You set of with a car that's already up to temperature .... after you've unplugged  :y
http://www.kenlowe.co.uk/pre-heaters/cars/diy.html
« Reply #8 on: 24 August 2010, 00:36:37 »
It's just a little box with a heater element and a pump inside. It normally fits in the heater coolant circuit and starts circulating coolant around the engine when powered-up, heating it as it does. So, you run it from a timeswitch set to come on before you leave in the morning and, ideally, remember to unplug it before you drive off. ;)
Broomies Mate
  • Bristol, UK
    • Stuff!
« Reply #9 on: 24 August 2010, 00:42:34 »
Thanks Andy and Kevin.
It looks intriguing, especially warming the passenger compartment (with the extra gubbins).
I only live 10-12 minutes from work, but it's all dual-carriageway.  Early in the morning, I'd like to put my foot to the floor, but never do because the engine hasn't had time to warm up.  This looks like a great way of getting heat into the system.
I dont see how it can be as effective as it says though.  Oil temp will still be at ambient temperature, right?
hotel21
« Reply #10 on: 24 August 2010, 00:45:20 »
Yeeeessss, but getting warmed by the heat getting transmitted through the block by the warmed water.  Could always fire it up a little while earlier....
« Reply #11 on: 24 August 2010, 00:45:39 »
I suppose it must be , apart from a little conducted heat. As the reast of the block is hot though I'd think the il would get hot much quicker.  ;)
« Reply #12 on: 24 August 2010, 00:46:38 »
True, it won't heat the oil, but the block and heads will be hot, along with the coolant. On a V6 the oil cooler will soon drag the oil temperature up as they work in reverse too. :y
I believe some emergency vehicles have elements in the sump to pre-heat the oil as well.
Broomies Mate
  • Bristol, UK
    • Stuff!
« Reply #13 on: 24 August 2010, 00:50:11 »
Cheers Guy's.
In a weird way, this system is a complete waste of time..... you are heating something which manufacturers spend billions on trying to keep cool  ;D
The heater in the sump is what I would like, but, too much work to save myself 3 or 4 minutes of 'slow(ish)' driving of a morn!
« Last Edit: 24 August 2010, 00:50:29 by Broomies_Mate »
« Reply #14 on: 24 August 2010, 00:53:24 »
Cheers Guy's.
The cold oil in the bottom of the sump would very quickly be brought up to engine temp if the rest of the block & coolant were already hot.  :y
Pages: [1] 2 3  All   Go Up
Page created in 0.036 seconds with 20 queries.
